New Pearl E-Pro Live Electronic Kit Jet Black With Brass Cymbals
$2,200.00
Listed on eBay too;
http://www.ebay.com....=item41602fb855
Discounted for SAU members...
Anything further let me kno;
Pearl E-Pro Live
e-Pro Live is a revolutionary electronic drum set that looks, feels and sounds like real drums. Never before has today's drummer been offered the limitless sonic capability and realistic feel of electronic drums on a drum set built with real drum shells, real brass cymbals, and real drum set hardware, all from the percussion industry's leader, Pearl.
The real look of the e-Pro Live starts with the real sizes of the drums. The set features 10", 12" and 14" toms, a 14" snare drum, and a 20" bass drum, so the drummer no longer has to change their playing mechanics to adjust to a set full of 8" practice pads.
The next component contributing to the real look of the drums is the real wood shells. Authentic Pearl shells, drum hardware and drum finishes adorn both versions of e-Pro Live. Two finishes are available: Pearl's new Artisan II finish, available in a beautiful Quilted Maple fade, and a durable black wrap.
Module
All of these great components couldn't reach their full potential without rich drum and percussion sounds generated from the r.e.d.box drum module (r.e.d. stands for Real Electronic Drums). The r.e.d.box massive 128MB RAM capacity accommodates 1000 High Definition Sounds, 100 High Definition kits, plus space for 100 user-created kits.
One very unique and exciting capability of Pearl's r.e.d.box is the Memory Switch, which gives you the ability to flash the memory and substitute a lush, super high-end drum set for the original acoustics. Pearl has partnered with professional digital drum samplers Toontrack, Sonic Reality, Ocean Way, Steven Slate Drums, Virtual Drumline and BFD, to provide the lush kits.
Hardware
Real Hardware. No one makes better hardware than Pearl, and the foundation of e-Pro Live starts with the modified DR-80E Icon e-Rack. The rack is expandable to add more drums and cymbals for larger configurations. All hardware is covered by Pearl's Lifetime Warranty.
  • DR-80E Icon e-Rack
  • PCL-100 Pipe Clamp x 3
  • CLH-80E Hi-Hat Holder
  • CH-80 Cymbal Holder x 2
  • TH-900S Tom Holder x 3
  • PC-8 Pipe Clamp x 4
  • UX-80 Universal Clamp
  • S-790W Snare Stand
Heads
What makes the e-Pro Live drum set truly different than other electronic drum sets is the real feel and response from the pads. Pearl's Tru-Trac Electronic Heads feature dual-zones that reproduce all of the intricacies the drummer is used to hearing when you play an acoustic drum. The smooth coating on the heads makes moving from drum to drum fast and easy.
Cymbals
The ECC cymbals featured on the e-Pro Live are Pearl's E-Classic high-end electronic cymbals, made with real brass. Traditional rubber EPC cymbals are also available. Both sets feature a 3-zone Ride, a Crash, and a set of super responsive hi-hats.
  • ECC 16T - 16” E-Classic Metal Ride Cymbal – Triple Zone
  • ECC 13D - 13” E-Classic Metal Crash Cymbal – Dual Zone
  • ECC 12S - 12” E-Classic Metal Top HH Cymbal – Single Zone
Extras
Included is my Dixon double bass kick pedal and one set of drum sticks as well as all the documentation and warranty that came with the set, this kit is well maintained and was my "showroom" pride and joy.
This set was kept out of any sunlight, and rarely played, perfectly displayed.
Exclusions
Drum Throne not included.
Extra hardware not included (stands, hooks, and boom stands).
Zildjian cymbals not included.
Pearl cowbell not included.
*Freight is via courier. Charges will vary depending on location, available prices on request.
Edited by A-K
  • 1 month later...
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
