  • Replies 89
Posted Images
going to make everything i can to save money in places so i can spend it else where haha. i just bought cad so i can draw up all my own drawings then get it all laster cut works out cheapser and looks better. the e36 has a few motors but iv been in a few and they are slugy and cost to much to fix. with the rb i know what the motor can do and i know how to work on them so makes life very easy ill post some pics tonight of where its at proberly should start a build thread
when you look at it in terms of used motors proberly around the same price. problem with bwm motors the km on the engines is massive your lucky to find one under 250xxx and if you do its very expensive to buy. a m3 motor is around 4 g with box. then you need to look at engine managment not much in terms of standalone but can be piggy packed but yet again expensive. the clutches are hard to buy as well and cost $$$$. BMW parts are over priced and hard to find. on my old e36 323i cost me massive amounts for everything but then was a nice car to drive just a bit doggy so rb will fix the problem. in my opinion the only bmw motor i would put in is the m3 as they are wicked and can turboed with eas
500whp and more importantly 500wtq is easily attainable with a thicker headgasket, turbo kit, and stock ecu. 2.8L m50b28.
Just my opionion, but I would've went with the 2.8L bmw 6 if availability and price were equal to an rb. easier build imo, more torque, and an arguably better transmission.
Is there much of a turbo e36 scene in australia? Its reasonably large here in NA.
they are mostly aspirated iv never even seen a turbo e36 before to be honest seen plenty sitting on chrome 20s with p plates hanging off the back none of that shit for me. nice set of m3 wheels sitting on the tire with a nice intercooler hanging off the front all the bling it needs is the turbo flutter haha
  • 2 months later...
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
