OK, so I have pulled apart a bunch of cars over the years, but all I've ever done with the speakers is rip them out and throw them in the bin.
Now it seems one of the speakers in the rear door has failed in my car.
How easy is it to find a drop in replacement? Will a $30 set from supercheap work for someone with wooden ears like me? What size do I need for C34 rear speakers?
https://www.sau.com.au/forums/topic/385795-new-speakers-for-c34/
6' inch front and 6' rear and can use same speaker bracket mounts. imo buy splits front and 3 ways for back, add sub and 4 channel amp later.
mine does ok, nothing special. 260rsstagea paid 40k for his audio visual install zomg. some fella has a neat sub box enclosure thread on here so check it out.
OK thanks guys, I assume from the replies that any speaker the right size should drop in, something like these would be OK?
$80 a pair at supercheap
If you're just running them off your head unit I'm sure those would be fine Dunc. Otherwise I'd look at a low end set of Kenwood/Alpine/Pioneer.
You can get a pretty good setup for under 2K. I got top range Polk 6" front and back with splits + sound deadening and amp. The sound is really crisp and it has plenty of down low, if you want everyone to hear what your listening to then add a sub so you can take the bass away from the speakers otherwise you don't need it.
  • Like 1
They definitely are not 6" in the front. I bought a set of Pioneer 6" for my S2 and they were too small. Had to get a spacer that sized it down to 6" from 6.5. Your best bet would be to get a set of 6.5" speakers. JB Hi Fi have a sale on at the moment. Like i said though, It was only the fronts that I have changed so far, so the rears may be slighter smaller. Won't know til this weekend :thumbsup:
Best of Luck!
Super Cheap have Pioneer's for an extra $5?
Anything around that price range should be fine if you're only running off the headunit, but I do hear mixed things on the Fusions. Don't want them to rattle themselves apart, just want them to make noise without being annoying :thumbsup:
Exactly correct Andrew, I just want to replace the factory stuff because one of them has failed. I don't want to go out of my way to buy crap ones, but I am just looking to run a factory system from the head unit i have....it will never have amps/top shelf head units/ additional speakers etc etc
Thanks everyone, it looks like I should be buying 6.5 front and 6 rear (and perhaps should measure first lol). I'll go low but not lowest available price range
I had the same problem with the surrounds separating on my rear speakers and replaced them with Kenwood KFC-E1662 6 1/2 " 3 Ways. Fitted well with only a minor bit of trimming if I recall. The fronts are a bit trickier so I haven't got around to them yet.They cost me around the $80.00 mark as I recall.I just checked on Supercheaps website and they are $109.00. These worked well for me with the standard head unit. Regards Craig
Thanks for all the advice guys.
I hit repco's 30% off speaker sale and bought 6"x 2way pioneer for the rear, and 6"x 3way pioneer for the front. About $150.
The 6" rear fit straight in with the 4 screws on the speaker into the factory plastic mounty thing. Just needed to join the 2 wires up to thee factory plug.
The front was a pita. The factory speaker is built into the plastic framey thing which meant either bolt the new speaker straight to the door, or cut up/modify/re-use the factory mount. I did the latter because I figure nissan knew more than me about speaker mounting and design. Took some stuffing around and use of self tappers to mount it....at least no-one will ever see that butchery. And the wiring was also a pain because I wanted to retain the factory wiring plug which was built into the mounting frame - more stuffing around with the soldering iron.
Does polarity matter in speakers? I wasn't aware it did, but the kit mentioned + and -....so I connected the blackest wire in each pair to the speaker (-). All works fine.
As for sound quality....I can conclusively confirm they sound better than 4x 20yo factory speakers (including one rooted one).
polarity on speakers does matter heaps if their is any bass it will sound like a puck instead of a doof use a multimeter put it on volts and check it. using the polarity around the way for too long will damage the voice coil in the speaker.
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
