Kevin, I believe so. from experience 10.5 +20 clears all big brakes (at least OEM 4pots brembo).
was going on to my evo but they are too aggressive for my liking.
dori33 dont lowball me, these are brand new.
https://www.sau.com.au/forums/topic/385811-dish-dish-dish/#findComment-6154047
They may be a problem with internal diameter.
https://www.sau.com.au/forums/topic/385811-dish-dish-dish/#findComment-6154116
sorry by internal diameter do you mean diameter clearance or offset clearance?
if it's diameter clearance i'm sure it will house 355mm rotors fine, because they dont have staggered lips.
but i wasnt 100% sure about offset clearance, although most likely it'll be alright being 10.5 +20.
Sir_rb, buy them :)
https://www.sau.com.au/forums/topic/385811-dish-dish-dish/#findComment-6154124
check them on the front of your EVO bro...... curious to see if the spokes will clear the 4 pots on mitsu's......
https://www.sau.com.au/forums/topic/385811-dish-dish-dish/#findComment-6154454
  • 4 weeks later...
what does +20 look like on a 33 gtr?
all good had a look at some... from the angle of the shot they look grey ? what colour are they gunmetal ? black lol ?
$1168 bux via this website for brand new shipped to my door
http://www.nlmotorin...oppingCart.asp?
Do better...
Just thinking... the rims are actually worth $162 bux each....so u trying to make ur shipping money bak aswell.... ill give u $650 bux and ill come get em today :)
https://www.sau.com.au/forums/topic/385811-dish-dish-dish/#findComment-6185518
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
