^Re: above comments about 18x11s: I had 18x11 +18 on my 34 GTR and although they looked sweet I couldn't get full lock due to the inside of the wheel rubbing against the suspension upright (Doing 3 point turns around hairpins at Galston Gorge is pretty embarrassing :P). I could have probably spaced them out to avoid this but they were already flush/just outside the guard on the front so it would have made it a fair bit worse.
Back to 10s now and I'm happy that I can turn moderately tight turns :)
  • Replies 91
would look very good. i just recently fitted matt black rims to my mnp r33 gtr n looks alot better than before in my opinion.
do a google search and some images should come up of the sl's on a gtr.
i will be putting some new photos up in the photography section once my abflug rear diffuser arrives from japn
also pretty sure that sunline racing used to use those tcII on their carbon r34 so they must be pretty good if a high class tuner in japan would use them for a time attack car
I am pretty keen to get them, but still not sure about the gun metal on a midnight purple hmmm
Oh really, that is a bit of a pain. I really would like a set of 18x11 or 18x11.5 would be even better because you can go to a 315 tyre (I think) comfortably.
n11smo is selling Gold ADVAN RG I (discontinued) rims with plenty of rubber atm.
Gold on MNP is superb!
Thread title should be:
TE37s the most over used Jap wheel in history?
Ha ha ah.....damn, I think you are right Ash...not come to think of it...damn
As if!
One of the best wheels to come out of Japan!
Totally agree. In my opinion, the LMGT4 and the TE37 are the best rims to grace a R33.
Cheers
I know i'll piss people off but seriously over GTC's,
One of the most over used Jap wheels. TE37's are common but bloody effective. I'd still buy a set for mine eventually as track wheels one day
I think the GTC's - regardless of face and lip whatever, is ugly and does not justice to a GTR or any Skyline at all. The spokes looks ugly in my personal opinion. I think the TE37 looks best then followed by the LMGT4 and that's about it. Everything else is a hit and miss thing. Boring I agree, but better be safe than sorry.
What other rims do people rock in their Skylines nowadays? Anything original?
In terms of the looks department, what are the major differences between a standard set of TE37's and the SL version?
Thanks.
Same style / looks but made slightly different.
A forged 1 piece wheel.
Success of 400 grams weight loss on the 18x10.5 size was achieved using the latest technology and mold form tooling while maintaining the same original strength and rigidiy as our current TE37 line-up.
By the way, where to buy replacement TE37 stickers? I personally find them ugly (the blue Volk Racing ones) and prefer to have the LMGT4 Nismo ones - anyone put these on as an alternative?
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
