Hey Guys,
Might be getting a set of Work XT7's, but before i go any further, i want to know how will they sit on my car?
There are many threads, and sorry if i have repeated, but i just can't find any info that I am specifically after.
When it comes to engines I can really relate, but when it comes to offsets, Im a bit sketchy.
Currently, I drive an R34 25GT, so its a non-turbo (unfortunetly due to p's).
The car has stock suspension, the current offset of the wheels are +30 (18x9.5 - 6 spoke 350z factory wheels).
The Work XT7's have an offset of +12 (18x9.5).
Need your help guys, will they fit? If they need modifications, what is needed?
All help is appreciated :).
https://www.sau.com.au/forums/topic/385819-need-help-12-offset-on-an-r34-25gt/
EDIT: I screwed up
basically, go outside to your current rims, get a ruler and measure 18mm, imagine your current rims are sitting that much extra outside the guard basically. I dont know how +30's sit on a 34 so you will have to see if that helps with what will need modifying, or if it is possible
Edited by 89CAL
I think OP screwed up with initial measurements.
Your 350z rims are 18x8 +30 right? (Not 9.5 wide). The wheels you want to put on are 18X9.5 +12
Inner clearence will be 1mm LESS
Outter position extend 37mm MORE
I have nil idea about R34 fitments, but those wheels sound more of a GTR fitment, not a GT-t.
Sorry guys about the wrong info, but yeah i ended up not going with the rims thanks to you guys :).
thanks heaps, if i didnt post this up, i would of screwed up big time. thanks again for your input :).
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
