Hi All,
Well after going and watching the event a few times, and seeing that we all now have a car at some sort of track ready stage, We have decided that we would be entering this year.
As it's our first time, we don't have any goals other than to have fun, and too find more about our car.
Although the event is some time away, we are all aware on how quickly time flies, and spots won't last forever!
After reading all the documentation on the Wakefield & AASA website, we cannot find out information on car regulations..
Speaking to a few driver's at last year's event. It all seemed quite relaxed, and the only requirement they kept saying was that a 1L catch can is required.
If anyone here can point us in the right direction on what's required by us to sort our car out..
Or even some pointers about refuelling, tools and equipment etc.
We won't be using our R32, instead a DC2 as it's going to be much cheaper for our first time..
Cheers
https://www.sau.com.au/forums/topic/385834-wakefield-300/
I havent done it either but keen too - wont be able to do it in march (cant afford) but hoping to do the superTT support races that weekend. Unless my mate needsd a co driver at last minute I'll co drive with his MX5 and go havles in cost.
AFAIK the car still has to comply with CAMS classes or built to that spec
then have to be AASA log booked too
https://www.sau.com.au/forums/topic/385834-wakefield-300/#findComment-6155638
yes full cage needed.
unless in mx5/similar where half cage/bonds roll bar is fitted
nup, its in march 2012
I posted a thread a while ago in here with 2012 wakie racing dates.
its in march as its on my 30th!!
https://www.sau.com.au/forums/topic/385834-wakefield-300/#findComment-6156255
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
