Yo GOT BOOST, :headspin:
Watched your runs and they were mad. It looked like you were going great after the first 11.7 run. Gald we left when we did as the track got even more slippery as it started to rain. That last run of 11.5 was outstanding well done.
As you could see from my times the NEW ECU is on song and now for some dyno time and Nitto's then back to the track for some PB times.
I did a 13.4 untuned ECU (thanks Fane for the yahoo's), but what was important was the terminal speed of 108mph/175kph that has me the most excited. So back to the track. hope everyone gets down and has a run.
Paully are you going to have a run next week????
GTRRRR, great run dude nice 12.5 , shame you are selling the car and the drift damage sux.
FANE, thanks for the support, get your car there next week. :)
https://www.sau.com.au/forums/topic/38585-slicks/#findComment-783826
sean,
I don't know if you already do this but, if you wait till the last couple of orange lights with the clutch pushed in , when in gear, and mash the go pedal in one hit and as the revs jump to 7000 sidestep the clutch. This works a little better than holding the rev limiter because you get a smallish amount of boost built as the engine experiences light load from accellerating itself. Next step antilag ? :)
https://www.sau.com.au/forums/topic/38585-slicks/#findComment-785765
    • I had a 3inch varex mid muffler with a rear cannon. It was quieter closed but it wasn't enough to pass a DB test which are very strict. Still needed a silencer as well.   So they do work but they are also not magic.
    • Ah ok, I called a while back and they told me that. From memory I couldn't see anything in the PDS but I called just to ask questions.
    • Plenty of modern cars run things like Varex exhausts, from HSV through to Ferrari. Their systems are usually setup so once you meet a certain condition (RPM seems to be the main kickover on the HSV from my experience) they automatically open. You could do the same some aftermarket ECU, IE, above X throttle, and X rpm, open the valve, otherwise shut, and then also have a switch to override it when you want a nice exhaust. On my boss' HSV Senator, I pulled the fuse on the variable exhaust, and that fails it into the permanently open position. He loved it, and was the exact amount of idle noise etc that he wanted from it, but didn't want to buy an exhaust for it incase it was droney or shit sounding.
    • I still haven't gotten around to fixing mine. Now the blend actuator has broken AGAIN. Twice in 20 years. tsk tsk.
    • I've not had issues with this for Shannons. It has been many years since I had a Skyline insured, but had things like the XR6T, and Subaru Liberty GTB. The most restrictive I've had is that it couldn't be parked on the road.
