Removed from new engine with 1000km of run in time. Would suit many different engine setups, Comparable to a Garrett GT40R but
outperforms !
Turbo comes complete with .91a/r T4 twin entry exhaust housing and i will include a turbo beanie with the purchase !
" The S300SX 9179 is the byproduct of Borg Warner/Airwerks engineering efforts to deliver massive boost performance with excellent fitment and value. This turbocharger is one of the highest power and fastest responding turbos that can fit in true street car. It uses a 7-blade Extended Tip compressor wheel w/ 66mm inducer & 91mm exducer rated at 82lb/min. 4" Ported shroud Inlet, 3" outlet compressor housing. Turbine side is a 79mm inconel turbine wheel which shares blade aero with the EFR family, on a 4340 steel shaft "
Google searches will reveal good results with the Borg Warner/airwerks range of turbos...
Asking for $800 o.n.o ( PM me or email at [email protected] )
Located in Tasmania, Will post at buyers Expense
Edited by rbr31andrew
https://www.sau.com.au/forums/topic/385876-s300sx-9179-borg-warner-turbo/
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
