  • Replies 82
Apexi multichecker now sold.
Still for sale (and many prices dropped):
R32 Gtr N1 turbos $1,000
R32 Gtr Garrett -5 turbos done approx 15,000km $1,500
Intercooler 600x400x100mm $150
BOV setup including stock Rb26 BOVs (return pipe now sold) $200
Intake kit including copy Greddy pipe to intercooler, twin pod filters $400
5Zigen 3”stainless steel turbo back exhaust $250
Stock Rb26 front pipes $150
Stock Rb26 exhaust manifolds and dump pipes $40 each
Intank Gtst fuel pump $80
Fuel pressure regulator $50
Turbotech manual boost controller $10
Wilwood 4 piston Superlight front brakes with Brembo 324mm drilled discs $1,200
Includes three brand new sets of spare pads, bracket adapter kit and braided lines.
Stagea rear calipers and rotors $150
Greddy strut brace front $120
Custom strut brace rear $100
Nismo control link set $550
R32 passenger seat, good condition $50
SAAS Steering wheel (no boss kit) $100
SAAS gear knob $50
Tomei 300km dash $350
M's turbo timer $40
Apexi 2” Power Meter gauge $80
Blitz R32 Gtr fibreglass bonnet $550
Top condition with N1 lip and aero catches
17 x 8 rims, good condition, no rubber $450
4 Door 1993 R32 Gtst shell, unrolling, previously registered in Vic, suit track use $500. Shell is mostly stripped out except for dash.
Various R32 Gtst 4 door shell parts including front guards, front and rear bar, indicators, rear tail lights, hubs etc ask away.
  • 4 weeks later...
Probably time for an update:
-Fuel pressure regulator, boost controller, fibreglass bonnet and shell now sold....
R32 Gtr BOV setup including stock Rb26 BOVs (return pipe is already sold) $200
Stock Rb26 front pipes $120
Intank R32 Gtst fuel pump $80
Intake kit including copy Greddy pipe to intercooler, twin pod filters $330
Exedy clutch $250, good condition
Greddy strut brace front $110
Custom strut brace rear $80
Nismo control link set $550 (suits gtst only)
SAAS Steering wheel (no boss kit) $90
SAAS gear knob $50
Tomei R32 Gtst 300km dash $300
M's turbo timer $40
Apexi 2” Power Meter gauge $70
Speco Meter 2.5" tacho $50
Racetech oil pressure gauge $50
Raisin Volt stabiliser kit $20 (no lowballs pls)
17 x 8 rims, good condition, also have spacers if you need, no rubber $400
Righto, from the list of things above the following are sold, everything else is still available..
Greddy front strut brace
Raizin Volt Stabiliser
Tomei dash
Apexi power meter
May consider reasonable offers on some of the other stuff so feel free to pm me :)
parts are in sydney and can post at cost or pick up is welcome
  • 3 weeks later...
Update!
These things are sold:
Tomei dash
Apexi power mete
Intake kit including copy Greddy pipe to intercooler, twin pod filters $300
Exedy clutch $200, good condition
SAAS Steering wheel (no boss kit) $80
SAAS gear knob $
M's turbo timer $40
Pics above or can repost
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
