the cover plate in the boot for the fuel pump is my guess my 32 had the same problem. the gasket was gone so i just run a small bead of gasket goo around the cover plate let it dry then screwed it back down problem solved for fuel smell. as for stalling clean the afm check your plugs
Edited by Bsa
https://www.sau.com.au/forums/topic/385909-fuel-smell/#findComment-6157601
