You can; I do, but they don't work as well as the dedicated forced orbit styles, because if you apply a decent amount of pressure, the pad doesn't orbit very well.
It's miles easier than hand polishing, and delivers surprising results if you're prepared to take a bit of time.
I'm sure one of the resident experts will have a better explanation; but that's it in a nutshell.
Most Orbital Sanders have an orbit in the range of 3-5mm where didicated polishes are around the 8mm mark. Not saying you cant use them, you can! but as above may take a bit longer. If you do use a sander dont use one that has been used on wood as they hold crap inside them and only takes some grit to fall out onto your work and you have induced scratches and swirls :(
Edited by R31Heaven
Its an Random orbital, not an Orbital polisher There RPM rating is higher.
I know its not a polisher. I just thought that it had to high an RPM to polish. Im no expert but I thought polishers had to have a lower RPM so they didnt burn the paint. But looking at the Concours 900 polisher that Waxit Sell and they run 2500-6500rpm. So I guess its not as far out as I thought
There are three types of polishers Random Orbital, Orbital and forced rotation. Random orbitals spin in a spiragraph type pattern so dont actualy spin, so they dont build up heat like a rotary which spin in a a circular motion, this why it is recommended to use an Random Orbital when your a beginer. Foced rotation do both. The Festool above also has a speed dial on top to slow down and speed up.
Thanks for the info,always have a doubt about the difference between each other,remembered that at work we used to have a Festo Rotex and when you switch from normal sander to the other mode if you pressed to hard it stopped spinning but it kept moving...wonder what happened with it...
Edited by southern_tango
hi
Both the Festool Random Orbital and Rotex can do wonders to your paint finish.
You can use either one, however make sure you get the right combination of pads and compound or finishing polish to complete the job.
rotex is mighty expensive though
Their slightly lighter than the boschgex150T which i use, but a whole ton more expensive!
as long as your machine wasn't previously used for wood though as previously mentioned :)
you might burn thru the paint either way you need to clean that thing spotless before use. I wouldnt use it myself too risky. a paint job cost too much to stuff around with a cheap sander to save coin.
the short handle will be harder to hold on a car without damage to it
a random orbital is quite safe at low speeds. rotaries scare the crap out of me, ive never tried one and most likely never really will, my random orbital on forced rotation is more than enough for me :)
but as antonio said - GOOD PADS :)!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
