Heya there :)
I'm selling my RB26 as a long motor to make way for a built engine.
Motor has done ~84k kms with even compression across all cylinders.
When the car arrived in Oz it had an oil cooler fitted straight away. I've done some track work with it and have decided to step up to a built engine. I have a 9L baffled and extended sump on the engine at the moment so there's no oil starve issue.
It's been tuned by HITman (a personal friend of mine for nearly 15yrs) with a Haltech Platinum Pro and made 317kw at the wheels on 19psi with -7s (standard intercooler/cams/MAFs and airbox fitted)
With a screwdriver handle holding open the airbox we saw over 330kw, whoever says GTR airboxes aren't restrictive need to buy a screwdriver and do some testing...)
It does have the following:
N1 water pump
Yellow Jacket coils (not even 1000km old)
Adjustable cam gears with new Gates belt and idler replaced a few thousand km ago.
Nismo thermostat
Also comes with coil cover, not shown in pics.
This motor is still in the car and can be driven before buying (no deposit on you, no ride, simple)
Obviously no turbos, exhaust manifolds, clutch/pressureplate.
Next problem is that I'll be away until Jan 16th, so don't expect any replies other than the random email till then. I'm sure we can work something out if you're super keen.
$2000, as it's in the car and you can drive it before it's removed. Better than a 'stab in the dark ebay special' with a photocopied dyno sheet!!
Mark :)
  • 2 months later...
  • 5 weeks later...
    • You're now in the unrestricted member group so upload away!
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
