Its an NPC 10" sprung button clutch, good for 300+rwkw, car is making 255rwkw atm
Clutch bites hard and the pedal is pretty soft. Takes a bit to get used to but once you do its an easy clutch to live with. Cost about $760 from memory. If your gonna get one think about getting there billet flywheel while your at it. easy to do it all in one go.
https://www.sau.com.au/forums/topic/385946-direct-clutch/#findComment-6156800
Posted 16 December 2011 - 11:23 PM
monty_r33, on 06 April 2010 - 09:30 PM, said:
Round 1: lasted 1 week
I had one in my rb30/26 running 580hp and the preasure plate smashed after a week and destroyed my gear box. I was only running the cluch in no launches at all. It was a single plate 5puk from npc
Round 2: built stronger lasted 3weeks
From the last time it shit its self I sent it back and had it rebuilt to handle even more power. Funny thing is I'm running less power then last time. Now 450hp and the piece of shit clutch let go yet once again but this time it smashed the box clean off the block. I was changing from 2nd to 3rd. I should of learnt from the first time it let go. Now I will use what I know works. Hks or OS GIKEN or a orc or back to mal wood to get a custom built. So I don't have to pay labour to remove the gear box and pay for a new box and clutch because some price of shit clutch can't handle half of what it is built for. Buyers be warned. And customer service is f**ked when you send them back. They try anything to get out of it
https://www.sau.com.au/forums/topic/385946-direct-clutch/#findComment-6157180
I had a twin plate with flywheel from Direct. I welded it once but it was my fault. Handled 8k launches in an Autech Stagea with 500rwhp. Was a light switch clutch but you get that when running big power. Steve was excellent to deal with and Ive bought many clutches personally and refered him to mates on countless occasions. Theo Wollet ran his clutchs in the drag car. Speaks volumes.
https://www.sau.com.au/forums/topic/385946-direct-clutch/#findComment-6158514
he said he's making 455rwkw,
you'll hear horror stories from any brand.. I had a couple with Jim's.... no point getting into that...
with that power go a multi plate, with over 600rwhp in a GTR with literally 100's of 7-8k launchs and over 20000kms, and still going I can vouch for the OS Giken 3SC ( triple plate ) not the easiest to drive but you get used to it.thumbsup.gif
my2cents
https://www.sau.com.au/forums/topic/385946-direct-clutch/#findComment-6158761
I'm having a NPC 10" ceramic button sprung clutch installed in my R33 GTR today (costs $1200 including flywheel). The GTR has around 380awkw. I was told that this clutch has proven to handle 600hp at the wheels so it should handle my power ok. I guess I will find out soon enough after running it in lol
I am having my OS Giken twin plate rebuilt - ready to swap back when the new NPC clutch gets tired.
Happy to report back in a month's time on the NPC ceramic button clutch.
Yea I am going twin plate but don't no which one to get npc or direct or Jim berry
https://www.sau.com.au/forums/topic/385946-direct-clutch/#findComment-6160509
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
