Hi i'm looking to get one of my rb25 intake manifolds looking as if it's new again preferably without just cleaning it with parts cleaner and painting it silver.
Doe's anyone know what is the best way to get that nice semi shiny alloy look the same as the factory appearance??
I'm not sure if the plenum and intake is cleared only from the factory or if it is just left bare alloy but i was thinking off sandblasting (handheld air compressor type) them on the outside completely then use wax and grease remover, let dry then spray with a non-gloss clear.
I sandblasted an rb30 plenum not long ago and it came up really clean but for some reason it went really dull and almost grey rather than that nice alloy colour. the compressor i used couldnt supply enough pressure but i cant be certain if that was the reason for this. Any help/info would be appreciated
blasted alluminium is a greyish beige colour, so what you are describing is not an issue.
for a blasting process to leave you with some shine you would need to use glass beads so that it peened the surface to create the shine.
So this would be the easiest way without painting? Any idea where i might be able to buy glass beads? Also i had another idea.. what about those ultrasonic solutions some cylinder head/engine rebuilder shops have where they immerse the parts in the solution and they come out clean. Are these tubs pretty standard in those kind of shops these days?
ultrasonic tubs wouldnt be - but if the plenum is shiny underneath the dirt (ie no corrosion yet) then a normal acid bath that are used for heads would do the trick
hare and forbes in brisbane would have the glass beads, but i would try an engine re conditioner first
sand blasterd and powdercoated silver any good powdercoating place will have a selection of coloures :) i paid the extra $ because it looks better and wont flake or shit like thay in a few months rockercovers where done 2 :)
  • 1 month later...
how much did the plenum/intake, tb and crossover pipe cost all up to get blasted and powder coated?
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
