Define stock??
Exhaust cam gears and power fc and a little more boost I saw a gain of 57kw at the wheels 203 to 260awkw and good fuel economy surprisingly
Cost wise:
Cam gears-$200-400
Power fc -$800-1400
Tune-$600-1200+ depending on tuner
Exhaust something over 3inch cost varies
Oh and search next time and look at the rb26 dyno thread
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6156338
Full exhaust 3.5inch after cat, cam gears as above then a nistune ($1100 supplied fitted and tuned)
Oh and a boost controller to up the boost to a max of 12psi
Agreed, except boost, 12psi is stock on a GTR, pull out the restrictor and you get 15psi, a good boost controller will help boost come on a bit sooner by not letting the waste gate "creep" open.
I use 15psi everyday driving/track events and 19psi for drags and dyno with no problems on stock turbos
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6156402
IIts got a 3 inch exhaust and pod filters. I haven't even driven her yet as I bought it while on swing. I'm really just wondering how much can be done.with a tune and maybe restrictor removed if its not already
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6162533
Tune can gears and restricter removed you will be able to get 240+awkw on the std turbos, depending on the tuner
I wielded 260awkw with std turbos, exhaust, 14psi, cam gears and power fc tune
Have a look at the RB26 dyno result thread, top of this page, to see different set up results
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6162964
JJust bought a set of adjustable cam gears from an Australian company called ozsome motorsports they SEEM to be.very similar to tomei you can pick like 10 colours they only.cost 90 bucks direct from the manufacturer with free postage. I'm going to take them into a garage when I get them to get an opinion if they think its ok ill see how it goes. if anybody wants feedback pm me
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164439
Throw away the fasteners that come with them, and go get some quality fasteners (hi-tensile etc) to use with them
Cheers have you heard of or used these before?any comments? The fasteners are they the bolts to the cam or the adjusters?
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164475
Adjusters, they tend to come with cheap fasteners. If/when they let go the cam gear will be set to the extreme advance or retard position which is guaranteed to smash at least 12 valves into pistons, 24 if unlucky.
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164492
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
