hey fellas im having a few issues....
for one my car is idleing high 1500 rpm (not surging nor stalling...)
and 2 the timing is all poo poo... what degree should the crank angle sensor be put at with a timing light ? (stock rb20det)
help help
currently sitting on 13*btdc
ive read all the help topics i can find
heres a vid
Edited by burnoutnut
U need to get th idle correct before setting base timing.
Have u tried adjusting the idle screw located on back of inlet manifold?
Check the throttle cable isnt to tight
do the 20s even have a idle screw on the back.... i was under the assumption they dont
