Just wanted to know what peoples opinions are on aftermarket manifolds that are floating around for the rb26.
Something like This claims to increase power by 15% on a standard engine which i find hard to believe.
Do these actually make any difference or are they just a waste of money?
https://www.sau.com.au/forums/topic/386012-aftermarket-manifolds/
The Nismo manifold only goes as far as saying something like a 1.8% power increase (although balancing all 6 cylinders instead of the stock one which puts too much air into cyl #6). If it's not designed by a reputable aftermarket company (greddy, nismo, hypertune etc) then in all likelyhood they may be worse off than the stock manifold in my opinion
i think youd be hard done by to max the std front facing plenum on the rb26
i mean, sure if you are making 400rwkw then you might be close to peaking its efficiency, but i dont reckon you would gain anywhere near 15%, like moodles said, nismo quote 1.8%
hardly cost effective
if its a dedicated track car and you have every other nismo part, go for it, but most cant justify the cost to gain zero
most if they are picky enough tune and trim cylinders 1 and 6 to compensate for the airflow balance across the plenum
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
