Got tired of the wiseling sound of the turbo(i'm not young any more...)so on saturday i took the pod filter off the car and put the air box back in place...and i looks to take longer to get to full boost(much longer)pod was apexi and airbox has a apexi panel filter so basically it's the same;before it used to jump in full boost now it takes a while and the car car feels sluggish so don't know what's going on...Any ideas????????????
Can you use the pod inside the airbox?
No ,as i said it's an apexi power intake ,even when it's smaller than K&Ns and other Brands still doesn't fit...
Intake leak near the afm?
Nope,checked that already (and damaged a hose clamp over tightening,but replaced it) BTW is it comon to have black deposits in the mesh of the AFM?
Yeh, just fine dust particles. Did you clean it?
No,didn't have nothing very soft so didn't want to damage it ,or you saying if cleaned the sensor with CRC9?(what I didn't)
Get some airflow sensor cleaner from autobarn mate. :thumbsup:
Got some CRC from burson the car is idling more smooth but still slug...anyway thanks for the advice it feels better after cleaning the MAF sensor(that shit really works)
Edited by southern_tango
    • What a wonderful journey to read. Loved the photography. Literally found this an hour ago and couldn't stop reading, plus checking out a couple of the links. Was interesting as you had a few mods very similar to my sons Gtt, including the sheetmetal homemade V-Spec II rear diffuser, can't be too many of them around the world. Only to find it sold about three weeks ago. Well at least I won't have to keep re-visiting for updates. Anyway, well done on not just the car but the well written story and descriptions, and of course the pics. Good luck on your next one. Rob
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
