Well I am moving to QLD in July, finally taking the step.
Odds are I will be staying in Brisbane with family friends until I find a job that will pay sufficiently for me to cover my costs.
I drive an A31 cefiro and will be taking this car over with me when I come.
Question is, would anyone be able to assist me in getting any work in either brisbane or goldcoast. I am willing to do anything work wise(within reason).
Look forward to meeting you guys when I am over
https://www.sau.com.au/forums/topic/38603-im-becomming-a-qlder/
Queensland is the best state in Australia full stop :) I made the move in December from Victoria (eek), and haven't looked back!
Can be hard to find work when you first move up, and I'll admit i was unemployed for about 2 months, but if you're keen and speak to enough people eventually you'll find something. It all works out in the end.
Is it just to be near me? *flutters eyelashes*
Oh and I do believe previous threads have reached the conclusion that a cefiro is _NOT_ a skyline. And now you know.
Its ok summoner, I'm on your side. *random glares at other people*
I'll give the cefiro a go in brutis. He's tasted nissan blood and wants more. (course, he got whupped, but thats hardly the point)
Andrew, old brutis got beaten by a sigma.... :)
But yeah, if you a forklift ticket, you shouldnt have too many probs getting something over here.
A 2.6L sigma with a turbo the size of a small african nation strapped onto it! Damn thing took 4 strong black men to lift into the car and the careful whipping and direction of a trained midget to get it all lined up and even fit in the car!
... And as a conclusion, your honour, I draw your attention to said sigma the very next week with a blown engine whereas Brutis (exhibit A) is still going strongly many months later. I have no further questions your honour, and rest my case. *sits down to applauding*
You were alone most of today weren't you?
Welcome Mark! It'll be great to finally meet you after many years of internet chatting :)
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
