I also want to know what road tyres are good for GTR, Mine hv 4 simi slick but the car is very hard to handle specially in the mountain. i am after 255/40/17 and how much are they? for the good sec hand one
I had Pirelli P7000's and Yokohama AVS V102's (I think thats what they were from memory)... *awesome* tyres, even when they were bald they had insane amounts of grip... but they wear out damn quickly.
Ive currently got Falken Ziex on mine (255/40/17) and they are crap, I wouldnt reccomend them to anyone. Only reason I got them is because I needed tyres then and there so didnt have much of a choice in that size.
The only tyre Falken make in that size besides the Zeix is the FK451 which is meant to be a pretty good tyre and average on tyre wear... im going to give these a try next time, and are anywhere upto $400 a tyre (the prices on these seem to vary quite alot).
Thanks for the replies,
I am seriously condiering the BF Goodrich g-force in the 255 40 17, for a couple of reasons. They recently out performed the Michellin Pilots in the wet, BFGoodrich is being pushed very hard by it's parent company Michelin in Australia. They come out of the same factory using the same technology as the Michellin's and are about $150~ cheaper than the Pilots. Without haggling these are about $350each.
Previously owning a set of Michelin Pilot on my WRX, which I found to be the best tyre I have ever used BAR NONE FULL STOP, even better than the Conti's on the Benz, if these BF's are as good and claimed to be better, then I think value wise they may be my best option... I'd appreciate any input on the matter.
I too am interested in tyres for my GTR - 265or275/35/18 tho to go on R34 GTR wheels (18x9)
The falkens i have on at the moment may as well be coated with oil they are that bad... (only 245's)....
i'm sure my GTR shouldn't go sideways as easy as it does :)
I have alway been a fan of Yokohamas. I just fitted ES100s to mine in 265/35 R18. I have only had the car 3 weeks but these tyres seem very good so far, have given them a workout through the mountains and went to Willowbank last night. Was a bit worried they might be a little noisey, but so far they have been pretty quiet too. Light years ahead of the tyres it was complied with.
jlnewton: is that on a GTR?
how much did they set you back
i also have always liked yoko's
Yep, they are on a GTR, I hate the big price jump from 17s to 18s! They were nearly $500 a corner. That was the best I could do. The V102s were about $600. I think it worked out about $100 more a tyre than Falken ST115 but I was less than impressed with my trial of Falkens. Falken 326s (I think) were $300ish a trye but I have heard less than favourable comments on them.
I can understand on the front but not sure why you wouldn’t want to go bigger on the rear. If you don’t have traction problems then there is no need you will just place more stress on the drive train but I’m sure more of us have traction problems :P
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
