I also want to know what road tyres are good for GTR, Mine hv 4 simi slick but the car is very hard to handle specially in the mountain. i am after 255/40/17 and how much are they? for the good sec hand one
I had Pirelli P7000's and Yokohama AVS V102's (I think thats what they were from memory)... *awesome* tyres, even when they were bald they had insane amounts of grip... but they wear out damn quickly.
Ive currently got Falken Ziex on mine (255/40/17) and they are crap, I wouldnt reccomend them to anyone. Only reason I got them is because I needed tyres then and there so didnt have much of a choice in that size.
The only tyre Falken make in that size besides the Zeix is the FK451 which is meant to be a pretty good tyre and average on tyre wear... im going to give these a try next time, and are anywhere upto $400 a tyre (the prices on these seem to vary quite alot).
Thanks for the replies,
I am seriously condiering the BF Goodrich g-force in the 255 40 17, for a couple of reasons. They recently out performed the Michellin Pilots in the wet, BFGoodrich is being pushed very hard by it's parent company Michelin in Australia. They come out of the same factory using the same technology as the Michellin's and are about $150~ cheaper than the Pilots. Without haggling these are about $350each.
Previously owning a set of Michelin Pilot on my WRX, which I found to be the best tyre I have ever used BAR NONE FULL STOP, even better than the Conti's on the Benz, if these BF's are as good and claimed to be better, then I think value wise they may be my best option... I'd appreciate any input on the matter.
I too am interested in tyres for my GTR - 265or275/35/18 tho to go on R34 GTR wheels (18x9)
The falkens i have on at the moment may as well be coated with oil they are that bad... (only 245's)....
i'm sure my GTR shouldn't go sideways as easy as it does :)
I have alway been a fan of Yokohamas. I just fitted ES100s to mine in 265/35 R18. I have only had the car 3 weeks but these tyres seem very good so far, have given them a workout through the mountains and went to Willowbank last night. Was a bit worried they might be a little noisey, but so far they have been pretty quiet too. Light years ahead of the tyres it was complied with.
jlnewton: is that on a GTR?
how much did they set you back
i also have always liked yoko's
Yep, they are on a GTR, I hate the big price jump from 17s to 18s! They were nearly $500 a corner. That was the best I could do. The V102s were about $600. I think it worked out about $100 more a tyre than Falken ST115 but I was less than impressed with my trial of Falkens. Falken 326s (I think) were $300ish a trye but I have heard less than favourable comments on them.
I can understand on the front but not sure why you wouldn鈥檛 want to go bigger on the rear. If you don鈥檛 have traction problems then there is no need you will just place more stress on the drive train but I鈥檓 sure more of us have traction problems :P
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 馃槄
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
