At Drag Combat, we were proud to launch Western Australia’s newest performance car club, Skylines Australia WA (SAUWA Inc)!!!
Those who have been involved with SAU from the beginning can attest to the fact that the formation of SAUWA has been a long time coming!
The prime objectives of the club are to promote friendship and courtesy on the road, and the responsible ownership of Japanese Import Vehicles. We expect to foster and facilitate a broad range of motorsport interests within the club, including legal drag racing, Motorkhana and other motorsport events, Driver Training initiatives, social functions, and other similar events...
Congrats to everyone who has signed up so far, and taken advantage of member discounts through our generous sponsors! thanks also to those businesses who have agreed to be associated with SAUWA.
IF YOU MISSED OUT AT DRAG COMBAT....
don't stress... memberships are available.
Here's how:
1.) Download the attached membership pack, which includes the membership form and the constitution.
2.) Fill in the form and email it back to Dan The Man (Events Coordinator) at [email protected] , along with any preference you may have for membership number (currently 50-100, get in quick).
3.) I will email you back and arrange the membership payment, your signature and the delivery of membership card, sticker etc....
4.) Membership Cost is $25
Stay tuned for special member offers and announcements!!
:D
https://www.sau.com.au/forums/topic/38612-join-sauwa-today/
  • Replies 85
yeah studied a bit of feng shui so thats what i know - plus all the asian people bugging me for "lucky numbers" on their number plates when i worked in licensing ..... 4 = death.
anyway sorry for whoring.
https://www.sau.com.au/forums/topic/38612-join-sauwa-today/#findComment-782862
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
