a car i bought(r32 gts) had a nismo front control link set
my question is can i use the castor rod and upper control arm on my r32gtr
its a production car so i cant use adjustable shit and i assume the nismo shit is far better than stock 20 year old shit i currently have
cheers in advance
pete
Fatz if it helps I can dig out the dimensions for the GTR stuff. From memory the Nismo GTR castor rod is basically as per stock just a few (4 or 5) mm shorter and a stiffer rubber.
As for the upper arm not sure it is any different in the steel to a sotcker - just harder bushes.
Pretty sure the upper arm is offset with a little more twist to allow for the increased castor, helps keep the bushes from flogging out.
From vague memory Nismo LCA for 32 GTR is longer than stock for increased camber and castor rod a bit shorter, but unsure if gts and GTR castor arms are interchangeable.
LCA's aren't the same (GTR's use 2 ball joints and an alloy arm), but 33 GTR LCA is the go as they're about 5mm longer than 32 GTR (like the Nismo ones) so you can also get increased camber this way (keeping the nismo uppers).
I've not done any of this myself, just random info that I recall from browsing, hope it helps your search.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
