Hi all, I hope this isnt a previously discussed topic, did search my best but probably missed it. mods please delete/block if already discussed.
I want to know if anyone has experience with this 'new'? pump from walbro, figures are impressive but is it going to fit and work in my 33 gtst?
I asked in another topic but wasn't really answered.
I have a 255lp/h one running somewhere around the 280-300kw mark with not a worry, but will be heading to about 340-350 ish soon, i dont have a problem with buying a nismo or anything but for the money can one of these exceed?
So, opinions? http://www.racetronix.biz/itemdesc.asp?ic=F90000262&eq=&Tp=
Cheers
https://www.sau.com.au/forums/topic/386130-new-walbro-f90000262/
  • Replies 49
I know right, seems ridiculously large flow, but even granted that it most likely wont flow that, should surpass what ill be using it for. Interesting read that thanks.
With those numbers it should support monsterous power... Sounds too good to be true
Ever heard of anyone trying one?
Maybe ill be a guinea pig unless there's a reason why not to give it a red hot go?
**CORRECTION**... Looking @ the graph again on the link, it's @ 14v/70psi with a claimed 320LPH :O
I'm even more dubious now, and would certainly like to see these tested independently.
The problem is all manufacturers claim/rate @ different levels, voltages, pressures etc. It's always hard to compare upfront.
I try to work towards 70psi as a "marker" and using 14v. Of course sometimes you have to improvise as figures are only supplied with 13.5v or 14.2v etc.
Anyway the reason behind "70" is the base. Which is what, 38-42 psi.
So +25psi of boost is 60-65psi. Round it off to 70psi and it should cover off most situations, or if you wanted to bump rail pressures running say 20psi and get a bit more out of injectors.
its about time they did something, the previous pumps are JUNK, these days I won't even let a car on the dyno if it has a walbro pump.
No matter what happens they allways eventually fail or they NEVER flow enough. I hate them with a passion they cause me soo much grief.
We put 2 in a supra, and after 3 weeks one just stopped working and it toasted the engine.
Would have to see how this goes, im going to order a few and try them.
I feel your pain mate...
My Walbro has been slowly dying in the arse (less than 2 years old and 10k's) after recent power upgrades - it cannot keep up with 250rwkw@14v :down:
There seems to be people happily running these numbers with them (e.g. dyno results thread)... but also just as many with problems these days!
Fuel supply is not something I want to leave up to chance... god knows what damage has already been done (hello knock!)
P.S Just purchased one of these 300lph Deatschwerks to replace the Walbro:
http://www.prospeedr...GTS%252dTs.html
It flows the same as an 044 and is a drop-in, in-tank replacement at a lower cost.
Edited by Checkbuzz
  • 3 weeks later...
Anyone got any first hand experience with these new pumps???
Also would the Deatschwerks 300lph pump support a 400-450rwkw gtr on e85???
Not a hope, considering you will need 1000cc injectors at a minimum, x6=360lph, but that flow is not at the pressure that you will need (approx 70psi)
Got my new pump today... looks little. but where impeller is is huge... wont know how it goes till next dyno run next month
Possible you could test it? Similar to the link earlier???
Would be VERY handy, and could include it into SAU Reviews :)
  • 2 months later...
  • 4 months later...
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
