I have here:
A set of Ohlins Damper Adjustable struts to suit R32 GTS-T.
Looking for $300 for the set...will split both for $200/pr if someone wants a pair only
Was going to experiment with putting the fronts on my S13 for mega Lowness...Apparently it's a bit of an old trick with A31 guys as well? Rears will also fit straight up to S13/A31s as well.
A set of Coilover type housings for S13/A31...Useful if you want to build a custom setup with Bilsteins/Konis as they are already sleeved, with adjusters and accept a 60mm I.D. spring
Taken from the top part -
45mm i.d.
51mm o.d.
54mm o.d. where the thread starts
The spring seat is perfect for a 60mm i.d. spring
$170 for a pair...Brand new
Aaaand a pair of S13 Bilstein adjustable rear coilovers. $250 These may require overhauling but I have not had them in the car. Heasmans quoted me $250 to do this....Pretty good when you consider that for around $500 you'll have yourself a fresh set of height adjustable Bilsteins!
Contact 0409 069 251
Located Adelaide Northern Suburbs
Edited by VLT025
  • 3 weeks later...
