mad... thanks heaps when i need them i'll write them all down and list them to save you from looking up the book heaps of times... :) i found the ones for the cam journals and just did them up to the same as the R32 GTR ones, i think they were 6.8-8.7 something (Nm or ftlb, unsure)
thanks again!
actually, just 5 quick ones, these are what i'll be doing first thing in the morning :)
Head Bolts,
Inlet Manifold to head
Inlet Plenum to Inlet Runners
Exhaust Manifold to head
Turbo to manifold
Thanks
Andrew
RB25 Cam brackets show 9-12 N-m
Head bolt steps:
1) tighten 29N-m
2)Tighten 98N-m
3)loosen all
4)Tighten 25-34N-m
5)Final Tighten 93-103N-m
Inlet manifold to head:
bolt 18-22 N-m
Nut 11-13N-m
Plenum to runners:
nuts and bolts 18-22N-m
Exh manifold to head 27-31 N-m
Turbo to manifold 25-39N-m
maximajim,
That book doesn't tell you how to troubleshoot VCT does it??
Mine doesn't seem to be working. The mechanic says the computer is switching the solinoid but nothing seems to be happening. The head has been removed and everything pulled apart, but now its back together it doesn't work. Can you see if it says anything in the manual.
Thanks
well my engine is going in tonight so tomorrow i'll hook up all the bits on the top and hopefully turn the key and it will start!!!
if you have a scanned image of the head and where all the vacuum and fuel hoses go that would be sweet!!!
Gi your in luck :P
http://www.rb25det.org/rb/vacuum1.jpg
http://www.rb25det.org/rb/vacuum2.jpg
calaistur:
Sorry no, no component t/s for the VTC
But since it is a soleniod just pull the plug and check the solenoid terminals for continuity.
fantastic... thanks HEAPS for that maximajim!!!
i'm almost finished! Just got the timing to do and put the radiator and other stuff at the front back together! Hopefully if it doesn't rain today i'll have her fired up!
i said this in another thread but i'll say it again... You are all champions... i love this forum!!! It's full of knowledge and helpful people!!!
calaistur:
I did that and there is continuity but it reads 117 ohms resistance across the terminals? Is this normal?? Does the manual say anything??
If anyone has an RB25 with VCT and a multimeter, can they check theirs for me?
Thanks guys.
Mine reads 10.2 ohms.
I've also tested it seperately with a 12v supply and it pulls the solenoid in O.K., so i'm pretty confident it should read around this figure.
I'd suggest taking it out of the head, and doing the above - just don't short the wires together! maybe use some small spade terminals with tape around them crimped to some wire. You will hear a click if it works OK.
Thanks for that. I just went and tested mine and I can hear the solenoid activating or clicking quite clearly. So I suppose that rules out it being the solenoid even if the resistance is a little high. I think it needs to go back on the dyno and to see if there is an audible clicking going on. If there is, then it must be a oil supply problem, if there isn't then it must be a ECU/wiring problem.
I doubt whether its an oil supply problem, as I have t'ed a hose into where the oil pressure sender unit is, to feed the VCT and my gauge is reading that I have normal oil pressure. So the other hose leading to the VCT should also be seeing that same pressure.
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
