Hi!
Couple weeks ago I drove my car fully functional to my garage and after that I have done few slight mods/mainentance procedures to it. And today as I started my car for the first time after I took it to my garage, it didn't work properly.
The car started nicely but immediately began to misfire on idle. Engine stopped misfiring on revs, but after couple times of revving the car stalled. Still starts nicely but if I even touch the gas pedal the engine stalls. The misfiring slightly decreased after the engine warmed up. Don't know if I'm just imaging it or is it just something I haven't paid attention to before but I can hear a slight "shhhhhh" after the engine stalls.
Stuff that has been done to the car after I took it to the garage:
-Plugs changed to NGK BCPR6ES, earlier ones was BKR5xx.
-ACC valve cleaned
-Throttlebody cleaned
-MAF cleaned
-Boost solenoid removed
-Camshaft covers painted
-Boostpipes polished
-Dump valve installed. Used to be just blocked with an aluminium plate
-Coils taped up because high rev misfiring
It's an RB25DET Spec2
Thank you for all your help!
Edited by lareee
https://www.sau.com.au/forums/topic/386180-rb25det-after-maintenance/
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
