Want To Buy R32 4 Door Weather Shields And Other R32 4Door Parts
Finally getting around to changing whole cold side. (Look at that sludge) lets see where this leads once it’s all together tomorrow.
0.5L sounds like nothing. But when it's a 25% increase in displacement, to a newer engine platform, and getting some speedy bits, it should be good! Compared to stock cams for the 2.5L, are these new cams mainly more lift, or more duration too (shifting the torque curve into higher RPM)?
Miraculously warps again despite every possible method of trying to ensure even torque on the bolts. I'm very tempted to blame the pressure plate at this point. Everything else as far as I can tell does not have any runout issues. I double-checked to make sure the friction discs are oriented correctly and the hub is properly seated on the friction discs. -
What about after you put it back together again?
MX5 goes into MX5 Mania tomorrow for the "camed 2.5 big block" swap 🤪 A week later than expected, but they found a lower Km engine than the first one and needed time for it to be pulled and inspected I did take it for its last spin with the 2.0 today, great day for top down driving, drove it to Altitude 1148 to lunch with Jackie Took the long way home down Bulli Pass, then home via the Nasho, lots of traffic, but typical for a weekend/public holiday, I had to time some sections to get "free air" for some of the twisties though, but a nice little cruise none the less, the car is handling great, and it sound awesome when I'm up it Looking forward to seeing the difference that 0.5 ltrs and some cams make
