hey guys i have a 98 R34 coupe with tiptronic auto. im having the usuall A/T light comin on n then being stuck in 3rd gear untill i switch the car off for a bit. the car has done 134,000km n has been doin it for about 4000kms off n on. i took the car to west coast automatics n had a new solenoid kit put in coz i was gettin error codes for the solenoids. they replaced shift solenoid a +b and the lock up solenoid n the line pressure solenoid as they came as a kit. 2 days later the A/T light came on and im stuck in 3rd again. this leads me to believe it either a fault with the auto ecu control unit, dodgy power supply or earth or the wiring. although it seems to b happening to alot of 98 model r34s with around the 140k mark so seems to be a wear issue or some sort. has anybony had this problem and actually pinpointed the cause and fixed the problem completely? i am going to check my earth leads and power supply leads and test the car then go from there and hopefully eliminate a few things off the list of possible causes.
  • 4 months later...
  • 1 month later...
its been a bit of a saga so far. the throttle position sensor was earthing out when the ambiant temp was hot which was triggering a/t mode. so i replaced that and it was ok for a while but its doin it again n the throttle position sensor if fine now so it has to be something else. the tcm still comes up with an error code for the turbine sensor although i hav replaced that sensor aswell. probably gonna get nissan to find the problem. they made the car so im sure they can figure out wats wrong with it. ive checked everything i possiblily can so either the tcm is screwed or theres a wiring fault. hav u checked what fault code its coming up with?
  • 11 years later...
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
