hey guys i have a 98 R34 coupe with tiptronic auto. im having the usuall A/T light comin on n then being stuck in 3rd gear untill i switch the car off for a bit. the car has done 134,000km n has been doin it for about 4000kms off n on. i took the car to west coast automatics n had a new solenoid kit put in coz i was gettin error codes for the solenoids. they replaced shift solenoid a +b and the lock up solenoid n the line pressure solenoid as they came as a kit. 2 days later the A/T light came on and im stuck in 3rd again. this leads me to believe it either a fault with the auto ecu control unit, dodgy power supply or earth or the wiring. although it seems to b happening to alot of 98 model r34s with around the 140k mark so seems to be a wear issue or some sort. has anybony had this problem and actually pinpointed the cause and fixed the problem completely? i am going to check my earth leads and power supply leads and test the car then go from there and hopefully eliminate a few things off the list of possible causes.
  • 4 months later...
  • 1 month later...
its been a bit of a saga so far. the throttle position sensor was earthing out when the ambiant temp was hot which was triggering a/t mode. so i replaced that and it was ok for a while but its doin it again n the throttle position sensor if fine now so it has to be something else. the tcm still comes up with an error code for the turbine sensor although i hav replaced that sensor aswell. probably gonna get nissan to find the problem. they made the car so im sure they can figure out wats wrong with it. ive checked everything i possiblily can so either the tcm is screwed or theres a wiring fault. hav u checked what fault code its coming up with?
  • 11 years later...
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
