Hey all I just ordered a set of 18x10 + 25 and me being the dick I am assumed they would fit my tyre guy reckons im going to struggle fitting them has anyone had experience with 18X10 under r32 GTR? If so what's needed for fitment and what tyres would you recommend?
cheers
Sam
https://www.sau.com.au/forums/topic/386195-r32-gtr-fitment-help/
Yeah id need at least 10mm can you get 10mm bolt ons? What's so bad about slip ons personally i don't trust slips but are they really that bad?
10mm will put u same as mine 18x10 +15, wouldn't go more than that
I don't think 10mm comes as bolt on only 15mm onwards
Just make sure u have enuf thread once the spacers are on otherwise will need to change ur studs to longer ones
i run 255's on my 17x10's, slight stretch was needed.
to my knowledge,any tire that needs stretching will effect your grip.
my 33 sticks down nicely but it can still spin the rears when i want it too haha.
Good luck with the fitment.
Edited by S1DWYSR33
Even with 10mm spacers still doesn't fit fml...id need at least 15 but then id be struggling to fit rubber...so the moral of the story is don't be a dick do some research first thanks for info lads=)...anyone want a set of 18x10 XXR 521s?
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
