Hi all Supersprinters - NSW
Here's some PROVISIONAL ONLY UNTIL APPROVED BY CAMS STATE EXECUTIVE changes attached.
Have your say - good to see time attack cars included - your thoughts on rules?
Type 4 and SV interesting!
Please voice your opinion to CAMs good or bad
Sport & Club Development Officer
[email protected]
Cheers
Vehicle_Regs_and_Rules_Changes.pdf
2012_Vehicle_Regs_Provisional.pdf
Interesting attempt to bring the regs back closer to what their competitors are doing. I still have absolutely no idea why type SV (or now time attack) exist outside the regular 1-4 classes. And they continue to rely on the meaningless rule of "road registered" without requiring "road legal"
Andrew, you will be please to know that Time Attack regs say:
2.6.2 Coil over suspension kits are permitted.
Hammerhead S13s are unfortunately banned.
but that rule's only in section "3 Open Category Regulations" - Hammerheads are free to run in Clubsprint! lol
The rule's really poorly worded too. Do they mean the width of the coachworh at that point, or at it's widest point?
Its funny that they got so caught up in cut-and-pasting WTAC rules they're just reiterating or contradicting other CAMS General Requirements... roll cages, exhausts, wheels, seats, harnesses etc...
You laugh about the "Coil over suspension kits are permitted" rule, but its not so funny when read in conjunction with this; "All Vehicles:- must only be modified as permitted by these Clubsprint Category Regulations". So this is all you can do to your suspension for instance:
2.6 Suspension
2.6.1 Suspension mount points as provided by the original vehicle manufacturer must be utilized.
2.6.3 Aftermarket suspension arms are permitted
that's it! that's all you are permitted to do to your suspension. No sway bars! No replacement bushes! etc etc... what retard writes this stuff?
Are you allowed to run a front splitter and canards?
They protrude the coachwork don't they... Or do they become apart of the coachwork ;)
If they are permanently fixed then they are part of the 'coachwork', love that antiquated word ;) My ruling for what it is worth.
PS: get a lawyer to go over regs wording before release, for crying out......
In every series I've seen they interpret coachwork as the original (or replacement) body panels. Otherwise there would be no limit on how wide a car could be if anything you add to the coachwork is coachwork. Canards and splitters generally are narrower than the widest point of the car's body.
If 'coachwork' is to be interpreted as 'original coachwork' then that should be made clear because obviously there can be two different opinions if that is not done. Not trying to be a bitch but properly drafted regulations or whatever should be as unambigious as possible to save aggro and misunderstandings down the track. I used to draft stuff in another life, it is an art and not something most people can do well without some training at least.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
