Hi All,
New to here, mates! Nice to meet you all here~
Today have 4x brand new tyres of Bridgestone Andrenaline RE002 (new gen of RE001) put on my V35. I was convinced by the tyre sales to use all same size: 235/45/17 Front and Rear due to he was offering better price and bargain. But when i read thru V35 mates's discussion in this forum, all have narrower wideth compared to rear width. What's difference? What will it affect on my handling? I just found it is a bit tight in steering but thought it is due to new tyre at front......
Pls advise, thanks!
Same width rubber all round is absolutely fine. Most people put wider aftermarket rims (and subsequently wider tyres) on the rear as the offset of the rear standard wheels on the V35 is horrible. I run 9.5" +20 rims with 235s on the front and 10" +12 rims with 265s on the rear.
You would be finding the steering slightly heavier because you have gone to a wider tyre than previous, plus the new tyre actually has grip, where your old worn out tyre probably had little grip :thumbsup:
Hi All,
Pls advise, thanks!
that is a very small tire but still within oem size so its fine, if you just drive from A to B then its good to be able to rotate wheels..
Our cars do like wider tires at the front than stock for performance but depends how you drive, i have 265 front and 295 rear in 19s.. And love it.
Thanks Andrew & Nate~ You've got big feet already to welcome the rainning season that should have no issue speed up in wet! You've got FULLY CONTROL!
Deeper question! Just checked V35's factory tyre size was 225/50/17 @ FRONT, 235/50/17 @ REAR, why Nissa set front width less than rear, why not set 235/50/17 all round which is earier to rotate when worn out? Nissan set Front narrower should have its meaning.......Can anyone dig out the answer for me? Thanks!
I agree with zei201 in thinking the reason is for grip.
The balance of our cars is such that if you track them and have same front and rear tyres you generally find the rears let go before the fronts and this becomes the limit of your speed through corners. ie at the limit oversteer ( at least that is what I found with my sedan on std tyres - same size front and rear.)
When you put on wider rears, as std on a most of the coupes, this balances the car much better at the limit and has more neutral steering.
I have found to 225/45/18 fronts and 245/45/18 rears to be just about perfect for balance of grip coming out of corners.
Of course for normal daily driving you are better off with what you have done because of the ability to rotate your tyres which the rest of us cannot do .
narrower fronts promote understeer, which the 'average driver' can handle better than oversteer.
IMO if you put the same size tyres all around, the rear will look like crap.
A little off topic, but I have 18in coupe rims on my sedan, the rear rims actaully have 'rear' stamped on the back of the spokes, and the fronts have 'front'. I am fairly sure they are the same width, offset, etc, so does anyone know what the difference is other than this stamp.
the rears will proably be wider, and they may not be able to be put on the front. i know with the Z33s this is the case
Maybe they are.. I will have to check next time i have them off.. although the front runs 225 tyres and the rear is 245, and you can notice the rear tyres protrude past the edge of the rim more on the rears, which makes me think they are the same rim width.. they are standard coupe 18s, so I though someone on here might have noticed it before.
your tire guy sold you the wrong profiles for a V35.
Try going over road humps and see if you scrape the bottom on stock suspension?
235/45/17 = 643mm Overall Diameter
Factory OD for V35/350Z come with 225/45/18 & 245/45/18 which have an OD of approx 660 - 670mm.
With 17s you should be running either a 50/55 profile tire to maintain the OD and also your speedo accuracy.
I think the offsets are slightly different.
No, the offsets are the same.. that I did check, both front and rears are +30
I am thinking possibly the rears are 8.5 wide and the fronts are 8. But will have to check that to confirm, otherwise I can't see any other reason for the front/rear stamps.
The 245 tyres are wider than the 225 by more than 0.5in, so maybe that I can still notice the rear tyres protrude past the rim more than the fronts.
Nah, fronts and rears are the same on a sedan
OEM sedan rims/tyres are the same all round and Coupe rims/tyres are staggered.
I have on m car 255 front and 275 rear tyres.
I also have a set of OEM 19' wheels and tyres for sales if this will help.
Spec for 2005 V35....GL
2005 Infiniti G35 Coupe
WHEELS AND TIRES G35 Coupe G35 Coupe
Wheels
17” cast aluminum-alloy, 6-spoke, silver
finish, 7JJ
S -
18” forged aluminum-alloy, 7-spoke,
titanium finish, 8JJ
O -
19” Aluminum-alloy, 5-spoke, polished,
FR 8JJ/RR 8.5JJ
O S
Tires
FR P225/50R17 V; RR P235/50R17 V S -
FR P225/45R18 W; RR P245/45R18 W O -
FR P225/40R19 W; RR P245/40R19 Y O S
Temporary space-savor spare tire in trunk S
Tire Pressure Monitor System S
EXTERIOR DIMENSIONS (in inches)
Wheelbase 112.2
Overall length 182.2
Overall width 71.5
Overall height 54.8
Front tread width (17”/18”/19” tires) 60.4/60.4/60.6
Rear tread width (17”/18”/19” tires) 60.6/60.8/60.6
Coefficient of Drag (Cd) 0.29 (0 degrees front lift)/0.28 with spoiler (0
degrees front and rear lift)
Technical Specifications, Features and Options, cont.
^^ if this is correct, the coupe 18s are all the same size??? only the 19s are different rim sizes front/rear..
looks like I am going to need to measure them, or remove them and check the sizes stamped on the back again.
It's starting to bum me out a little considering I can't find a single manufacturer that supplies the 224/45R19 rubber that's recommended for the fronts and I would like to figure out the best formula before RAWS receive my '09 V36 coming in from Japan soon.
I was keen on getting a set of Dunlop Sport Maxx as they served me well on the old Maxima but the front tyres seem to be the stumbling block here. Considering they must be readily available in Japan and most of Dunlop's top-end tyres are manufactured there, I'm hoping that perhaps something is available on a special order perhaps.
Anyone else already done this homework or should I embark on it myself? :)
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
