Man I love those cam & tune packages that add 100rwkw they are just the bomb!
It's just a pity they don't exist!
Dunno what mean by they don't exist cause they sure as hell did when I got mine done.
Stock vx clubby 255kw at the fly. Made around 190 atw
In went OTR CAI, mafless tune, cam, 228 duration ( can't remember LSA, 112 or something) exhaust was already done though headers wernt ideal and had standard cats
Made 285 rwkw out of an LS1 with 130,000 km
Pretty sure it can be done.
  • Replies 52
Happy dyno's in my opinion - I've tuned countless ls1 ls2 l98 all the way up to ls7 with varying sizes of cams and I've never seen that kind of power on our dyno. I've made upward of 350rwkw but it's always been with cubes (427) and large cams 238@50 and beyond.
STD ls2 auto with exh and tune will make around the 230-240rwkw mark with a cai and similar size cam 225@50 you will only see around the 280rwkw mark with low rpm torque loss!
I tend to agree,
Most Cam/Spring/exhaust LS1's I have seen make 280-290 and depending what cam are lopey as hell
L98's have much better heads though (bigger ports and valves than an LS2) So 300+ isnt out of the question imo
my mates ls1 ute has a tune/exhaust/spring/ otr/ cam in the upper 230's at .50, it makes 270rwkw through a auto.
other mate has a vx with a l98 conversion, with same stuff but a 237/242 cam it makes 330rwkw on a mainline with a manual.
for the dollar spent compared to the old stuff they are great!
cheers
darren
I tend to agree,
They do have larger ports and valves but I've never really noticed any difference in power out of the box and they seem to respond the same amount once cammed as well. Its all about port velocity just ask nathan higgan what he does with the heads. Aspirated performance isn't about bigger is better - unless your talking about cubes!
PS - everybody's got a mate with LS that makes a sqillion hp. I just find it funny that cars I've tuned with similar mods to other cars but with 50rwkw less seem to keep up!
do it! there is a reason nissan went from the vq30tt to a vk45de in there gt500 car, and in gt1. sounds like arse but goes great. no lag, flat torque curve. and it will do 100k befor any rebuild is needed. t56 box is also tough as nails. abit slow shifting but strong.
also whats the go with engineering these days?
If you can pull it off, go for it. sounds good.
No Replacement for Displacement.
Price of engine Sounds so dodgy..
P.s i have nothing against the V8 Swap...apart from it being a dirty ChevGM motor lol
its goin to cost ALOT of money for this conversion unless u can do the fab work yourself, but dont get discouraged as the benefits are worth the effort. the simpicity of an NA V8 means alot less stuff to go wrong and so much torque everywhere!
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
