Damn page cannot be displayed.
Ill write it again :)
Last night i was down at the local oval near my house when i witness some pathetic youngens drive down to the local primary school oval and destroy it by doing burnouts for a few minutes and then driving out and hurting it off..
Im pretty sure i got there licence plates. But just wanted to know in your opinion if its worth reporting this or just letting it go.
report it ..... show no mercy for the trevs ..... they wouldnt keep quiet if it was one of us .... actually they would probably throw bottles at our car then go report it to police.
heck, you guys are pretty harsh!
And the "if it was one of us" justification is a bit rich.
I've never done anything like this, but I've done my fair share of dumb shit. It's easy to say they were destroying property but if you've ever done anything like tow a bin on your towbar......
theyre dumb kids doind dumb things - but it could be worse. they could be doing 200km/h through the suburbs or doing nuts in a crowded area where they could hit something or roll the car. at least they had the sense to go somewhere clear and open.
my thought is same aas Dans .... why should they get away with it? if they get away with it they'll just keep coming back and doing that and other shit. Its a form of vandalism!
lol what the? why would you start a thred to fined out weather to report it or not. ethier way its your word against theres the cops wouldnt do crap.
Because acutaly some1 else already reported it.
There must of been more than one witness now and because there car was pretty dirty so theres probly grass stuk in the wheel arches.
I was in favour of reporting them because there a bunch of hardcores, if every1 starts ripping up ovals then thats another thing cops will start blaming "hoons" for.
sorry mate not having a go, just thought it was werd. well you know you havnt done the wrong thing im just not sure it would of done much good, these things would be geating reported alot i would say. i dont want to stear you in the wrong direction good effert
Being a "soon to be teacher" report them.. and zanda... if it was u i would still report u.. its distryoing property.. Just think of how disapointed thoes kids will be when they get back from their school hols to see their oval ripped up...?? No doubt they wont be aloud on the parts that have to be regrown.. therefore not bealbe to play sport... That just cos some twat in a crummydore wanted a bit of a thrill
whats so bad about it being done on an oval? im sure everyone on here has had a go at swingin nuts on the road and goin driftin etc whether it be wet or dry so i think people shouldnt be so hipocrytical....
Would the view on the matter change if it was a carload of people in a skyline?
Does anyone else agree?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
