  • Replies 52
not sure if people realised but you can actually change your Origin name to match your forum name
now i know some people may not want to align their names up but someone might
enjoy
http://www.origin.com/au/change-id
You've fked up the settings then.
I cant remember what it is, but one setting will cause that constantly. Ill try find out which one
The problem is related to the TS overlay plugin
Go and disable that somewhere in the settings, and you'll be fine. Had the exact same thing.
oh oh sorry i didn't mean g15 overlay
umm
In Settings-Plugins, I've only got the top two plugins ticked
I think I had DirectX plugin ticked before (cause I wanted to figure out whose voice was whose while playing) and that crashed it.
Pretty sure that's the one I was talking about...? Not sure. It's christmas day and i'm a biut drunk
umm
That one worked :) Thanks.
Funny it only started happening about a week ago. Prior to that I never had an issue.
Edited by Cozi
  • 7 months later...
Could someone please give nee the low down on what the f**k I need to do in order to play this game now? I bought the special edition or whatever, karkand thingy...didn't play for a while and now there's like no servers :(
Check your filters, Troy. If you have one wrong filter selected it can get rid of all the servers. Try removing all filters and see what happens.
I'm keen for Saturday night. One caveat though, I often have to go AFK to look after my daughter and/or wife.
You have to own BF3 bro!
And you want to help me with DayZ? dfarq
Positive it's not the filters. It's either as if all the servers I played on previously vanished when I downloaded the huge patch recently, or I have to now also purchase the most recent expansion pack to continue playing as I normally did.
Seriously dude. Seriously. Just you wait. Seriously.
(I've got nothing)
(I've got nothing)
as the others said there must be something wrong with your filter settings, can you post a screenshot of your server browser settings?
There are still lots of base game & karkand servers around. Though I am liking close quarters
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
