  • Replies 58
QUOTE=strutto]Sedans...
Not 4 doors...
:P
I always call it a 4 Door....that way I can be reasonably sure that the average "ordinary Skyline" drivers can work out what the difference is :wassup:
only pic I've got handy at the moment
http://members.optushome.com.au/jay51/Black%20M%20Bar2%20(1).jpg
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-782697
Work in Belmont live down Rockingham way.
Don't know exactly how many Impul's were built but I think it was more than 100.
How much did I pay hey.....hmmmm Let's just say I don't think the dealer I bought it from knew (and neither did I when I bought it) how rare they are over here. From what I know Matt and I are the only 2 R33R's on SAU
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-783989
I have a R32 GTS-T Sedan
Pics
http://board.performanceforums.com/forums/...2125#post772125
Outside:
GTR front end including bonnet
R32 GTR wheels and brakes with lots of rubber, with callipers painted black and gold
Lowered 1.5 inches
Dark tinting
Inside
GTR dash and display i.e gauges are GTR set up with NISMO 260km/h speedo
Pioneer head deck, with Alpine speakers
Engine
Full 3inch exhaust
Upgrade R33 turbo
GTR fuel pump
FMIC
Boost controller
GTR inlet manifold (This was a bitch of a job!!, but well worth it)
Running 1 bar, but could run a lot more with better turbo
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-784243
4 doors = GTS-t with extra practicality! plus you always get a wave from other 4dr drivers
all the 'lines i test drove were 4 doors. come to think about it, i've never been in a 2 door skyline!
very tidy spooks :)
mine's fairly std with an R34GTT rear wing & turbo, apexi filter & a 3inch turbo back exhaust. oh & some fugly r33 rims
https://www.sau.com.au/forums/topic/38630-4-door-owners/#findComment-784386
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
