  • Replies 81
i agree, no need to go anything more than the AD08's. You'll have plenty of grip and even more power than you'll need for your first track day.
for reference, start out around 34-35'ish cold psi with the AD08's, seemed to be quite happy around the 36'ish mark after a few hard laps. Traction Tyres weren't 100% what to go with as they haven't had too many customers for reference, but they suggested that and it seemed to be quite good.
34-35 strating seems a bit high for me,
4 laps of winton 2 weeks ago, I was slack started at 36 psi and had them at 44 by end. and car felt as shite as it should have by then.
normally I start around 32ish for warm up knowing I'll be around 18-40 after a good session then drop them to 36ish as soon as come in from first hot session.
then check them after each session to try keep around the 36 area.
end of the day adn I let them cool I'm around 28-29 but don't really recommend going out at that press on street tires, work your way up.
Hi Martin, don't know about Driver Dynamics Defensive Drive course, maybe different. But I did a J Bowe one around 10yrs ago and they did a bit of theory about seating position, tyres, braking, handling concepts etc. The in car stuff was wet emergency stop, moose test, slalom etc. So if the daily driver has ABS, ESP all it really highlights is the limit of the tech. Don't get enough goes to aim to get the max without triggering. Drivers tends to be, too gentle and need a prod to reach the limits, then move to next exercise. IMO, if you have a vehicle you're comfortable with driving that hasn't got the tech or it can be switched off, use that. After all off street is the only safe/legal place to practice at the limit handling.
Martin - she's better off doing the Defensive Driving Course in the car she uses everyday.
If she wants some prep for DECA, tell her to bring your car to one of the Skidpan Days :)
  • 1 month later...
