As the title suggests, i am after shift kitting my R34.
Too be honest, i dont know much about them and how it will benefit my existing auto gear box, I have just been told its the way to go if u have an auto.
i have been searching various threads and i have notived a lot of people are going to MV Automatics in SA to get their's done, i have also noticed their are different types too (stage1, stage2...).
What would be the most suitable shift kit for a daily drive, but has that extra punch too?
On estimate, would anyone know how much i would be looking at incl. installation?
Cheers
https://www.sau.com.au/forums/topic/386317-shift-kit-for-r34/
There is an easy and cheap way to do a simple shift kit that any auto-trans place should be capable of doing..
Drop the pan, remove the 1-2 and 2-3 shift accumulator pistons & springs from the valve body, replace with welsh plugs (50mm IIRC).
Well, that's why I asked about how modded the car is. How tight you make the shifts on an auto depends on what you're going to be doing with it and how hard you're going to be hitting it (such as it going to the drags - which given you're in SA is not the case, at least legally). If you're making big power then you need to shorten the shifts up to control clutch slip and stop the transmission eating itself. The more power, the more you shorten the shifts.
The shorter the shifts, the better the shifts are when you're hammering, but the nastier they are when you're just driving normally. So, as with all such modifications, there's compromise to be had.
Just arbitrarily saying "I want a stage 2 kit" (because all the cool kids have got one) is the wrong approach. (I'm not saying that's the way you were asking, but it was almost that way). The correct approach is to lay out the power and usage pattern to the tranny guys and let them tell you what is a sensible way to mod the tranny. Or, if you're going to ask on a forum, it's the same. Tell the story, invite the full recommendation.
cheers
Edited by GTSBoy
  • Like 1
Shift kits are a pain to live with...I can just tolerate mine because it has a loose stall that dampens it a bit, but mine is a proper built box with extra clutches etc which doesnt help.
But plenty of low speed diff clunks and neck breaking upshifts to be had
I did the welshplug mod to the tiptronic in my Stagea and for a mildly modded car that was struggling big time on the 1-2 shift it made a WORLD of difference but wasn't overly harsh in anyway.
The pretty much instant 1-2 shift makes for good times when the old bus starting spinning the tyres :whistling:
@GTSBoy
So in the sense that more power requires shorter shifts..... If i am to mod the engine, would i be better off getting a shift kit after i have done these modifications, and getting a shift kit that can maintain that power?
too be honest with u, i dont know what mods i'll be doing next, and thats why, when i was looking thru the forums i noticed that the majority of people who have auto's whether they have smaller mods or have done extreme mods, on average i have seen that people have installed stage2 kits.
I dont have all the money in the world to turn my car into a dragger, and i dont plan on racing at all.
Im not the type of person to take the attitude of being 'cool' cos i have a skyline either, all i want is my car too be responsive when changing gears in tiptronic/auto.
i agree with bubba.. i had my auto serviced and while they were at it did the accumalator mod. cost me $20,shifts are instant and firmer..gets rid of that hesitation between gears. forget the shift kit in a stock street car its not needed.
Edited by rgr34
  • 2 months later...
Funnilly enough, I was told by MV that the kits do result in a stronger box, but then again I raised the question before I sent my transmission off to them to build it.
The stage 2 kit is completely OK for driving around on the street, the first to 2nd shift can be a bit 'extreme' when putting along at 20kmh, but it's not like a neck snapping, tyre screeching experience driving along normally at 20% throttle.
At least mine isn't. If you are in SA, then MV are the obvious choice to go to. I am pretty sure they can do whatever you need done, but you have to know what you need first (like most things!)
Get the welsh plugs, change the fluid, put in a bigger atf cooler and save up for a manual box!
Can anyone recommend a place in Melbourne for doing a basic AT service and the welsh plugs mod? Someone who knows Tiptronic boxes?
My housemate actually has an MV Autos built box for sale. Unsure of exact specs on the box (shift kit, stally etc) but if you plan on power mods in the future it would be a great bargain. PM me if you're interested.
  • 4 years later...
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
