  • Replies 231
Tyres and suspension are your big ones in a Gts t
Yes it's the key for the low 60' time.
I know a stock GTST with a 100 shot of NOS and drag radicals did an 11.4 IIRC, which is quite stupendous.
never happen on street tyres
drag radials as a minimum and you would be looking at 550+bhp at the crank to get you a high 10 at around 130mph after lots of practice
Auto or manual?
Manual.
So that is ~350 rwkw then?
What is a 350 rwkw car gonna do on street tyres then? I don't just mean $100 a corner china spec but semi-slicks if necessary.
What tyres?
And can the person drive?
Two most important things over power IMO. If you can't drive you'll need a LOT of compensation (power & auto probably the easiest)
I'm talking potential really. Like how a $10,000 piano can sound better than a Bontempi keyboard but only if the person can play it properly.
as others have alluded too it will take more than just power.
Circuit semi's are rubbish on a drag strip, will need the correct tyre's for the job
plus you could have 350rwkws but if the car is laggy as hell then it wont run a 10
I know of a 1000hp R33 GTR that barely runs 12's because it is so laggy.
Have you dont any drag racing at all before?
I have done a fair bit and I still suck balls at getting a manual car off the line well
What suspension do you have? sub frame mods?
Well it is not my car per se. I am talking a GTST in an abstract or hypothetical sense.
But thanks for asking about my car anyway. :thumbsup:
Suspension wise I have HKS coilovers, whiteline sway bars, just the main subframe bushings are poly, camber arms. Have a Cusco mech LSD as well.:cheers:
well if it is hypothetical
4 link rear end, RB34, Auto, 5000+rpm stall and n2o to get it on boost on the start line
Seems a bit pessimistic when you consider a stock one has done an 11.4 with a 10lb bottle of laughing gas.
dropping 7/10ths at that level is a lot
eg twin turbo soarers are running 11.6's with just a front mount, boost and ECU
10's is a whole other ball game
obviously you dont need half of that stuff I listed
you don't need any of that stuff.., unless you want to run 8's haha
cheers
darren
Edited by jet_r31
There was a R33 GTSt for sale a while ago, had a powerglide, high stall, GT35R etc and did 10.9 or something. Apparently only 288rwkw too.
Yeh but if it was manual it would make at least another 35-40rwkw, but dyno figures don't mean shit, they are all over the place at the best of times.
cheers
darren
I did a 12.3 in a full weight 25/30 GTST 5 spd, 350 killerwasps, GTR diff, 245/45 17 Dunlop Direzzas, Bilsteins and kings, I had about 30 goes at trying to better it at the SAUNSW drag day, terminal speed was 123 mph, 60 foot was 2.? seconds which was crap but the tyres just kept bagging up, if you got some good drag radials and stock shockers you will most likely get a better 60 ft time, BUT, in all honesty, you may be dreaming.
10.99 is along way away from 12.3, Im hoping for 11.9 next time but I will be using drag radials.
:cheers:
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
