  • Replies 231
I was neck and neck with an R35 GTR down the main straight of EC when I only had 320rwkw and im sure his wasnt standard.
So do we think that a properly set up 370rwkw+ 32 gtr would smoke an R35 from a rolling start at 60kph?
So too a standing start if the bloke in the 32 could drive?
I've often thought about this and I've come up with YES
and YES depending if the 35 uses launch control, which I don't think would happen much on the street
the R35 from the factory has proper launch control (full boost before you even start moving) not to mention the larger displacement and much newer tech but it does have a lot of KG on the 32.
without actually doing the test you cant say for sure though.
well what does a 35 run down the quater stock standard? somethin like mid 11's...alot of this good quater mile time can be put down to the launch control
have seen a few 35 run at WSID and they have been high 11's without using the launch by the sound and look of it...
an R32 with 370rwkw+ is potentially a 10 second car
yes i know there are other factors but im talking about a perfect world here
Theres a few clips on Youtube.
Well this in a roll on from 2nd. 600hp R35 v 700hp R34 GTR
So this has gone from a 10 sec RWD R33 GTS-t, to people that don't understand ATTESA.
Now it's onto R35s that have DSG. :laugh:
Surely this is ready for the Wasteland now?
It is.
Quality thread so far...
Yea well this thread got high jacked ages ago so im gettin in on it
just finnished watchin some other clips on youtube as well, havent seen this one yet
Well the DSG (cough...auto) does give quite a big advantage on the strip, also the R35 GTR has more gears so can make better use of its torque curve. It's almost like a continuously variable transmission.
To sum up, a 10 Rb25 is not all about having the power. Its the potential to get it down on the ground, from the get go. You need the launch, you need the traction, you need the quick smooth gear changes etc. You really cannot compare an R35 to any other manual skyline. Unless you're chuck norris, you can't out shift a DSG. Hell even chuck norris cant do it.
Power to weight will always win in my book
In a quarter mile track awd means nothing.
Most efi comes with launch control
Mine is set to 6.5
Mine was jumping to the left
Lowered the pressure on the right tire and helped alot.
So suspension and tires are destructive counter measures against awd cars.
I sure fear no awd car out there.
They are top prey in my food chain. ;)
So u drive around the street with less tyre pressure in your rear right tyre?
Or do u just jump out and lower it when ur at the lights after pulling up next to a GTR
This thread has come a long way from the first page, maybe he didn't read the OP where it was talking about street tires and full weight.
None the less it is a true statement. Ive seen some videos of VL's and rotors make some pretty quick passes with street tyres. The VL is a fat sloppy car while the rotors are generally fitted into a chassis which weights easily under a ton.
Fat as in they can in no way be compared to skylines in terms of their suspension work. My cousin has a VL which ran 12's or 11's and it had almost no suspension work. Fat as in when you smack the brake it rocks like a boat and handles like a boat. Skylines might be big and heavy but they really do not handle like boats. They are 1250Kg, 100kg lighter than my GTST.
Edited by SargeRX8
I think that's why they are good for drags straight out of the box though, the soft wallowing suspension aids in the rear squatting and the front lifting, whereas the Skylines with there sporty suspension is a bit to firm for hooking up.
Although the VL does handle a bit more like the Queen Mary when going around corners.
I think, LOL.
    • Ah ok. I seem to be mixing it like everyone else does so not sure what's happening. Will experiment with it more.
    • Depends on what you mean by OK. First up, was this done cold or hot? Are they reasonably consistent? Yes, they are reasonably consistent. Could be better. But unless it has had a build at some point, it is a ~30 year old engine and you'd expect some variation. Some of the difference could also be in user technique Is it good compression? Well....not numerically, no. New they were >160 psi. The one at 140 would be fine, in that context. If they were all ~140, you'd be reasonably happy. But the one that is @120 is twice as far down from the original numbers as the one @ 140. But.. (again)... technique can play a part in the absolute magnitude of these numbers, and the quality/state of repair/accuracy of the pressure gauge is not known. In the context of the above, the compression tester that was used last on my car is regularly compared to a known good pressure gauge. Not calibrated, exactly, but compared to a reference instrument that is not used for any other purpose, so cops no abuse. So we can trust the measurements off that tester. But another tester in the same workshop wasn't being compared against the standard and was reading a good 30ish psi lower. When you're reading 100 psu but the engine is really doing 130, you can make bad decisions.
    • More likely from tiny bubbles in the filler/putty. Maybe be less aggressive when mixing it. Perhaps invest in a vacuum chamber to pull the air bubbles out?** **I don't know if this is a thing for body filler. I see hardcore epoxy makers degassing their mixed resin on the regular.
    • IIRC, the speedo on these is fed from the sensor in/on the snout of the diff.
    • They were. I bought the AWD for experimenting but racing it would disqualify or disadvantage me from a few race classes. Def getting a FWD for racing.
