  On 29/12/2011 at 4:26 PM, Tony de Wonderful said:
You mean like how traction control was removed, engine sizes made smaller and rev limits reduced?
De-engineering comes from F1 rules not what the teams want. They would be driving computer controlled V8 turbos with continuously variable transmissions if they had free reign.
turbos banned, that fan car was banned aswell, how radical was that!
cheers
darren
  • Replies 231
  On 31/12/2011 at 3:24 AM, Lithium said:
Here is a mates R33 from a few years ago doing 10.6, stock RB25 below the head gasket and on straight 98.
Says in the comments 450rwkw and running a .82 GT3540? 128mph Trap speed doesn't really add up to 450rwkw lol
Edited by Super Drager
450kw on 20psi on a Dynapack set up in such a way it read real generous.
Not fiction parts:
Jun cams dialled to make peak power near 8000rpm
Thicker hg
Garrett GT3582R .82 at 20psi on Bp98
Stock below hg, only failed because oil pump drive gave up after a day of clipping a 8000ish limiter, and doing tens in a full weight car
Pretty sure it was on Chinese manifolds too
Not fiction parts:
Thicker hg
Ahhh that explains it, sounds like a 5spd too, very impressive!
Fast RWDs. What is the fastest GTS-T/GTT in the world? 9 secs? The fastest Supra I know of is Ryan Woon's in the States which does the quarter in 8 secs something. Its a demon- look it up in youtube
Project GTST in the UK has done a 7.45
woon was the king for a long time,for street type manual cars but he got beaten a long time go, SW is the manual king, auto wise theres faster..
cheers
darren
Edited by jet_r31
Jesus Christ, f**king SAU and its retardedness on dyno results.... despite any redundant wahhhing you guys have about the fact every dyno on the planet don't read the same as your glorified brake testing machines the car has done a ten, my link to the vid was about the ability to do a ten and nothing to do with power figures.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
