Gearbox in. R32 auto Tailshaft getting chopped up and R33 yoke fitted. Opted to go with the 2 piece as I've heard nothing but dramas from 1 piece setups. Started mucking around with the intake pipework setup, decided that a blow off was too much bother.. ahh the joy of MAP tuning.
Getting close to the great wire up, OEM coilpacks are now only AUD330 delivered and for the loom, you can just buy the plugs if you are going aftermarket loom for your ECU!
Having a few dramas with the power steering setup, seems like every RB has a different orientation of the pump depending on AWD, HICAS and model. Getting the combination wrong means either the pump doesn't fit or it is positioned to far back or forwards for the drive belt. Going to try a 26 bracket with 25 non-hicas pump, fingers crossed.
Also learnt that the heater core piping is much smaller diameter between each model, thus, you will need the water fitting from an RB20 to fit up the heater setup without mucking around. This is tricky to get off and requires a 27mm deep socket to get off easily. Be warned, it is very easy to round the fitting with a spanner even with the engine out of the car.
In any case, feeling the progress now, mostly because ACE workshop is doing such awesome work :).
Didn't even know they were an option to be honest. They don't look *that* much cheaper for the extra work but given that I already have a set of OEMs I guess i'll keep it in mind if any fail me.
Still arguing with powersteering. Trying a Neo bracket and pump now because all the 20/26/25 combinations we tried didn't work.
  • 3 weeks later...
Just a little update.
The race between my first born and this car is currently neck and neck, however, I think sportsbet has odds on baby to win :(.
The trust waste gate which wouldn't hold pressure. Ace Workshop pulled it apart and found a leaking rubber diaphragm and some horribly shoddy workmanship by a former owner.
Trust Wastegate Before
After some tender love and care it now looks like this:
Trust Wastegate After
I had the wonderful task of picking apart the RB20 loom for the wiper controls.
Before
RB20 Loom before
After
RB20 Loom after
I did manage to source a Neo powersteering pump after several false starts and it all bolted in without issue and lined up beautifully (except for being slightly bent, le sigh).
Most of the ancillaries are now connected with just a couple of bits and pieces to tidy up. After the intake is finalised, it's finally time to get wiring.
The engine bay currently looks like this:
Progress at 25/08/2014
Edited by Sarumatix
  • 2 months later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
