Hey guys,
I'm looking to sell my v35.
But just confused about how much it is actually worth.
Is the data on redbook.com.au accurate?
How is the market for our cars? Should ours be more expensive or cheaper than the 350z when compared to them by the same year model...
I've advertised it on Carsales, it's been 4 days now but no calls... :( been averaging 30-40 detailed views per day though...
https://www.sau.com.au/forums/topic/386368-v35-value-on-redbook/
Errrrrr dude, seriiously, you are concerned about 3-4 days and no calls? It will take you 6 months AT LEAST to sell your car - you may not have a single phone call in that time, unless you advertise it at a bargain basement price (and even then you will struggle) ..... the car market is the worst ever. It took me 8 months to sell my old R34 for $18,500 and it had $20k of mods on it .... different car, but you get the idea.
Our cars are a double edged curse ... they are awesome and seem unique cos no-one knows what they are and the average Joe thinks they are worth MUCH more than $20k-$30k (people are SHOCKED when I tell them mine is 8 years old and only worth $30kish). But, by the same token, because no-one knows what they are, people aren't out there looking for V35s. And those that are have a LOT to choose from (check around on Ebay, Carsales, car yards etc). Sad but true.
^^ Good advice. The majority of the population don't even know they exist, so if you are really keen to sell it, you should be trying to get it out there in everyone's face.. park it in a prominent position with sales signs on it (if you local council will let you do this!).
I have to agree that no-one seems to know how much they are worth. Just a quick look on carsales will usually reveal several cars of a similar age/condition/features, with as much as a $15k price variation. As a reference, I brought my 2005 6MT 350GT sedan with 75,000km for $19k about 3 months ago on carsales, and it has been sitting on there for several months.
Mine is on carsales for nearly 6 months now and got 3 phone calls, 5 SMS's and about 4 scams.
My advice is just be patience. My car price will stay at $23k as it is until I really need to sell it. Good luck.
hey victor, how did that deal go for the car....
Hey Shiva, the potential buyer is waiting to get this loan approved. I should know something next week. As far as I am concerned, it's not a scam as I've done research on his local bank and have talked to few people.
Well that's a relief I thought something was wrong with my ad...
Maybe I will consider a dealer trade in...
But thanks guys!
Hey mate, trade-in price will most likely be very low. I showed my V35 to a Nissan dearler where I bought my other Nissan just to know what they think in August. They only offered me $15k! :(
Edited by VNS 24
Hi mate, do you mean our V35 only worth $15k if you trade in for other cars? That is unbelievable...why all the V35 become so cheap recently? I still remember I bought mine 28k from dealer last year.ohmy.gif
That's just by itself, not a trade-in. You can get more with private sale.
I think it's just all about being patient and waiting for a right person. When that right person comes along who knows the real value of your car that's not cheap compare to others because it's been taken of, you won't be disappointed.
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
