I'm trying to decide what throttle body to run on a Plazmaman plenum.
It is my RB25 GTST and aiming for 300 rwkw.
I am assuming the stock throttle body will choke the engine a little and would a 72 mm be adequate?
I know Q45 bodies are around but I think they need an adapter flange welding on?
I don't want to run a 72 mm if it will lose me power.
https://www.sau.com.au/forums/topic/386403-throttle-body-size/
e.g. Proengines as per above - 364kw with standard t/b (can't edit my posts atm).
Yeah but you might have got 374kw with a 90mm TB.
I just don't know.
I'm thinking of settling on a 72 mm TB. My pipe work is all 2.5" so can't see 72mm being a restriction as such.
My main issues is bolting it on to the Plazmaman. I know the Plazmaman takes the stock one, and I know the 72mm fits the stock plenum. The 90mm TB's need an adapter I think? So the 72mm would just conveniently bolt on w/out a need for an adapter?
Y r you wasting money. Heaps of rb25s out there making over 300 with stock tb the amount of restriction I would make is nothing plus you will loose some mid range power
How is it going to lose mid range? I think you mean throttle sensitivity?
Stock throttle body will be fine. Saw in an imports magazine the other day a silvia with an RB25 and 500+ hp with a GReddy plenum and the adapter to fit the stock throttle body. No problems with stock throttle body unless your building a show car or making rediculous power
Thanks for the responses.
There are some calculators on the web in places.
I might play around with them at some point, but I am thinking to just stay stock, mainly for cheapness and modulation.
Calculator
  • 1 month later...
  • 3 months later...
Calculator
Interesting, that calculator suggests 72mm when I enter my engine variables. I also run a plazmaman plenum and interested in trialling the throttle body. Hoping they will do me a return policy on one in case the performance doesn't match their asking price
I went will the Plazmaman throttle body for looks and that the stock NEO throttle body is about 8 foot long... Haha... I chose to stay with a near stock size tho of 66mm... I guess for street use the throttle response was important...
Get this straight.
Throttle response will be greater with a larger throttle. This is only because a larger throttle will give you a more rapidly increasing throttle flow area as you open it. ie, more mm2 of area opening up per millisecond.
Throttle controllability is maximised with a smaller throttle - well, at the bottom end of the opening range, anyway. If you need to be able to modulate small openings, then you need a smaller throttle rather than a larger one, for the same reason as given the he above paragraph. A larger throttle gives yuou bigger changes in open area per degree of rotation of teh shaft - ergo, less sensitive.
Apart from any restriction put up by the throttle at WOT, a different throttle cannot really cause a loss or gain in midrange power. If it is small enough to cost top end power, then it will cost mid range a bit too. If it is so big that it is not any restriction at all at the top end, then it will be even less of a restriction in the midrange.
/obvious.
So, does that mean you have seen someone leave everything else the same except change to TB and realise a change for better/worse or no change?
I understand people make perfectly good power with a certain TB. The reason I am considering it is the TB is obviously sized for a certain lbs/min of air. When you go from 110rwkws to 310rwkws I dont think its out of line to wonder what affect that has on pressure drop through the throttle body....or more to my thinking what its doing with regards to the velocity of air through it and in turn the pressure drop you have when it goes into the larger plenum and cylinder filling
So with what your saying, the smaller throttle body is still better for daily driving and throttle control on street?
I did a fair bit of asking about all this when I bought my plazmaman kit, but happy to hear others opinions....
If you get up to the 300rwkW area (or possibly even less) then I have no doubt that you'd free up a few kW by putting a bigger TB on. If you calculate the gas velocity through things like the TB at the temperature and pressure of post intercooler air you'll be pretty frightened by how fast it's going (compared to industrial gas flows where we try to keep stuff below about 30 m/s if we can, to prevent excessive noise and pressure drop). The very high velocity leads to high pressure drops along lengths of pipe and through fittings and valves (like the TB). Upsize it, lower the velocity, significantly lower the pressure drop, gain a psi maybe, which is a psi that the turbo doesn't have to make, and drive that the turbine doesn't have to provide and hence less back pressure on the engine.
But you have to realise that the cross sectional area increases with the square of diameter, so you don't need to go from, say, a 66mm butterfly all the way up to a 90mm. That's 85% more flow area, which you probably don't need. But what you certainly don't need is the first degree of rotation off closed to give you 185% of the flow area that the original TB would have, if you're trying to drive it normally.
When you say that a TB is designed for a certain lb/min of air flow, that's not quite right. When we design a valve to act as a flow control valve, we start out with a few numbers. Those are, the mass or normal volume rate of the gas, the starting pressure, and the amount of pressure drop that we're willing to accept over the valve when at full flow and 100% open. The designer has freedom to choose that last parameter based on his needs. But importantly, when boosting up an engine, we are not just changing the mass rate of air, we are changing the starting conditions as well. Let's say we double, or triple the boost from the original 8 psi or so. At the same gas veloctiy we're flowing a lot more gas through the valve straight away. Even if we end up with the same pressure drop as the original design, we'll still be flowing bucket loads more air than originally. My point here is that control valve design is complicated - and the application in question here, being automotive compressed intake air, makes it harder to mentally estimate what is going to happen when you make changes (say to boost). So one of the best guides to what to do, is to look at other's experience. That's an engineering basic - copying those that have been successful before, avoiding what those who have not been successful have done. Use their experience to decide which numbers become important.
Absolutely. I wouldn't be tempted to go much bigger than 80mm under any circumstances where the car is still supposed to be a street car. Probably even smaller.
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
