yeah thats where im thinking..... i have a plazmaman plenum so its going to be a little tight there..... im thinking of doing some changes to where the air filter goes and the piping there so i can fit it over on the left hand side of the car...
as tempted as I am to make this difficult Jeremy......just drop it at Brad's with an order for a 3l catch can, and then pick it up 2 days later with a 3l custom catch can at an excellent price.
Your car can sleep next to my race car while there if it will make it feel less lonely.
c'mon Mark....share your oil experiences and get Jeremy to just kill himself in despair.
Did you make any progress after last weekend? Or did your car co-incidentally catch fire on sunday morning?
Your car has a GTiR next to it still.
I was considering moving your car to upstairs (floor is now rated to 5tonne)
lol...it will leave one day....just need to finish the damn house first! If you are going to get rid of anything, get rid of that shitbox pulsar.
Jeremy...why the need for CAMS compliance? Are you thinking about getting a logbook? If so, a cage will be the big change. If a logbook is not important I can't see why a 3l catch can would be any more appropriate than a 2l one. If your breathing is under control 2l vs 3l is no big deal.
Duncan, cams schedule b clearly outlines the need for a 3l catch tank for any engine over 2000cc.
I was given lots of grief about it at eastern creek yesterday.
I also have to seal off the boot from the cabin now 100% due to my surge tank.
well....I don't know who's event it was at EC yesterday....but that is why most clubs don't run under CAMS rules, they can be a PITA.
In any case, Brad can help you out with the catch can and all other schedule A and B requirements. Unless you are racing a cage is not required by CAMS but some clubs might require them when you are on slicks. I'd never want to discourage a motorsport competitor, but there are plenty of events where a cage is not required - a cage is that key decision where your car is no longer a reasonable daily optio, and if you are going to go that way there are lots of other options worth considering.
Jeremy,,,who was running the day,,,I would have come if I knew and quite frankly I like it done that way so you know whats what. It's all safety stuff in the end. Don't seal the boot area off,,,just re-locate the fuel surge tank under the car.
Go with Brads idea of putting it on the drivers front,,,that way you have no oil or hoses anywhere near your turbo or manifold. If room is tight and you still have your windscreen bottle in the corner,,,think about moving it into the boot area.
Cheers
Neil.
Hi Niel, it was a driving sports day. full on drift day. lots of fun.
they had a cams licensee or official down there doing the scruiteneerig and while he was tough i thought it was fine. the rulse are the rules, so you must comply.
i'll take the tips on the location of the oil can, but the washe bottle is already gone and well its going to have to be 3liters......hope these is enogh room...
who is and where is brad and his workshop?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
