yeah thats where im thinking..... i have a plazmaman plenum so its going to be a little tight there..... im thinking of doing some changes to where the air filter goes and the piping there so i can fit it over on the left hand side of the car...
as tempted as I am to make this difficult Jeremy......just drop it at Brad's with an order for a 3l catch can, and then pick it up 2 days later with a 3l custom catch can at an excellent price.
Your car can sleep next to my race car while there if it will make it feel less lonely.
c'mon Mark....share your oil experiences and get Jeremy to just kill himself in despair.
Did you make any progress after last weekend? Or did your car co-incidentally catch fire on sunday morning?
Your car has a GTiR next to it still.
I was considering moving your car to upstairs (floor is now rated to 5tonne)
lol...it will leave one day....just need to finish the damn house first! If you are going to get rid of anything, get rid of that shitbox pulsar.
Jeremy...why the need for CAMS compliance? Are you thinking about getting a logbook? If so, a cage will be the big change. If a logbook is not important I can't see why a 3l catch can would be any more appropriate than a 2l one. If your breathing is under control 2l vs 3l is no big deal.
Duncan, cams schedule b clearly outlines the need for a 3l catch tank for any engine over 2000cc.
I was given lots of grief about it at eastern creek yesterday.
I also have to seal off the boot from the cabin now 100% due to my surge tank.
well....I don't know who's event it was at EC yesterday....but that is why most clubs don't run under CAMS rules, they can be a PITA.
In any case, Brad can help you out with the catch can and all other schedule A and B requirements. Unless you are racing a cage is not required by CAMS but some clubs might require them when you are on slicks. I'd never want to discourage a motorsport competitor, but there are plenty of events where a cage is not required - a cage is that key decision where your car is no longer a reasonable daily optio, and if you are going to go that way there are lots of other options worth considering.
Jeremy,,,who was running the day,,,I would have come if I knew and quite frankly I like it done that way so you know whats what. It's all safety stuff in the end. Don't seal the boot area off,,,just re-locate the fuel surge tank under the car.
Go with Brads idea of putting it on the drivers front,,,that way you have no oil or hoses anywhere near your turbo or manifold. If room is tight and you still have your windscreen bottle in the corner,,,think about moving it into the boot area.
Cheers
Neil.
Hi Niel, it was a driving sports day. full on drift day. lots of fun.
they had a cams licensee or official down there doing the scruiteneerig and while he was tough i thought it was fine. the rulse are the rules, so you must comply.
i'll take the tips on the location of the oil can, but the washe bottle is already gone and well its going to have to be 3liters......hope these is enogh room...
who is and where is brad and his workshop?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
