Today first day on holidays so before washing my car had the idea to make my washing bucket more efficient so ... that's what I came with...
I used:
Plastic milk crate...........1
Plastic Bucket.................1
Texter................................1
Jigsaw .............................1
Cut out the bottom of the Milk crate just around the square edge with the jigsaw,then using the texter mark a circle using the bottom of the plastic bucket as a guide.
Cut the plastic of the milk crate a couple of mm. inside the guide line and clean up any plastic bur made by the jigsaw (you don't want pieces of plastic floating in the water).
Insert the plastic circle into the bucket and you are done ...you have a bucket where to rinse a mit and all the dirt will sit on the bottom...
Simple but works...
https://www.sau.com.au/forums/topic/386430-washing-bucket/
  • 3 weeks later...
A Very Good Idea Buddy.
a little time to save heap of time polishing.
Pat yourself on the back.
may be simple but improved upon .
Need 2 buckets,you cut a section out of 1 that will slip inside the other, depth is up to you.
you then throw/cover this with fly screen and insert into other bucket, screen side first.
It simply jams itself in place.
only reason is less surface area for grit to sit on so it falls threw, in theory.
This is a modified version of a filter I made for sand blasting, bigger foreign pieces block pick up.
I've even filtered bulk Rd marking paint with this, removed dry skin off top.
next time you replace a fly screen keep a piece, or cheap at Bunnings by the mtr.
It reminded me of the filter I already have and can modify.
don't let anyone laugh at the lengths you go to, to look after your drive.
Good one Tango.
https://www.sau.com.au/forums/topic/386430-washing-bucket/#findComment-6187851
you then throw/cover this with coarse fly screen and insert into other bucket, screen side first.
only reason is less surface area for grit to sit on, so it falls threw, in theory.
Good one Tango.
https://www.sau.com.au/forums/topic/386430-washing-bucket/#findComment-6187854
Just made new bucket setup with flyscreen false bottom.
Had 20 Lt, and 15 Lt, cut the 15 Lt fitted this into larger one, looks good, false bottom about +100mm. given it a go shortly, my GTR need a wash.
Especially as it's not long been polished so I certainly don't want to scratch it.
Tango your the man.
https://www.sau.com.au/forums/topic/386430-washing-bucket/#findComment-6188658
    • I'd do it all again in a heart beat. Well, not all, I'd make some different choices in which mods. But I'd definitely still spend all the money.
    • Hey y'all, Looking local to USA, for just side skirts and rear bumper or half bumper. Pics for reference below: Top is east bear style rear bumper, bottom is uras style rear half bumper. Side skirts are interchangeable.  Thanks y'all!
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
