mates stripping his track only ceffy
call or message 0403428996 dont pm me
gramlights 17 9+14
5 114.3
no tires $500
granaids 17 9 +20
5 114.3
half cooked 235 45
$500
mint front lights with laurel style crome grill
$350
mint side indercators
$50
front castor arms
adjustable green in colour
$150
5 stud conversion
s14 rear hubs calipers and rotors
front has custom sleave to fit s13 knucles
s14 front rotors and calipers
perfect for s13 so dont need to change knucles
$500
GTR rear swaybar
$120
38mm cusco front swaybar
$120
40L alloy fuel cell
has near new 044 with mounting bracket
all lines, fitting and filters to suit
$700
CST coilovers
fully adjustable
$800
3 inch exhaust with one resi
cat back, ok condition
$100
rb25 turbo
made 198kw
$200
NISTUNE ECU
tuned to 25 turbs exahust and fron mount
$500
rb20 r32 coilpacks with modded loom to suit ceffy loom
$250
rb20 ceffy loom
$150
bride rail
$200
rb extream heavy duty
6 puk rated to 250kw
had bugger all use
$450
GTR fuel pump in ceffy cradle
$120
a31 purple lable AFM
comes with silcon joiner and pod
$100
bare shell with all pannels no bumper or lights
still had cradle and rack plus lots more
$800
pics availble via txt
https://www.sau.com.au/forums/topic/386445-heaps-of-ceffy-goodies/
  • 4 weeks later...
  • 5 months later...
gday there man , just wandering do you have pics of the bare shell if you still have it for sale ?
regards anthony
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
